Dudadiesel Diaphragm pump
Old Feb 9, 2011 | 04:28 PM
Tom D's Avatar
Tom D
Originally Posted by ttttmaxx
Amazing. Thanks again for your help. I will go the 5 then 1 also and see it it goes on the next batch. I settled the magnesol 48 hours then actually drained the paste straight out the bottom of my cone tank until nothing but BD was exiting. It worked out pretty well I thought. Can I get by with 24 hour settle?
YUP. That's how long I settle mine.
Old Feb 10, 2011 | 06:56 AM
ttttmaxx's Avatar
ttttmaxx
What do you guys run? B50, B100?? How low of a temperature can I get away with running B50? This morning the temp was sitting at 15. This is sort of out of the ordinary for my area but curious as to how much I can push the limit. In the past I set a jar outside in the mid 20's and noticed by B50 was cloudy but still very flowable. In the teens I have not check it (mainly cause it rarely gets in the teens). Little scared to run it when its that cold. What are your experiences. Thanks Maxx
Old Feb 10, 2011 | 09:41 AM
binuya's Avatar
binuya
Here's the only way to tell for sure. Rarely gets into the teens here, but it will on occasion. This pic is at 28F.
Old Feb 10, 2011 | 10:38 AM
fabmandelux's Avatar
fabmandelux
A lot depends on the raw oil that was used. Hydrogenated oils will jell at a higher temp than non-hydrogenated oils, and Soy based bio has a higher jell temp that Canola.
My bio is Canola based, non-hydrogenated, and is good to 0 deg at B-50.
Old Mar 1, 2013 | 12:45 AM
hayabura's Avatar
hayabura
thank you very much
diaphragm pump
vacuum pump
Old Mar 16, 2013 | 10:01 PM
Rushmore X's Avatar
Rushmore X
Originally Posted by hayabura
thank you very much
diaphragm pump
vacuum pump
welcome to the forum!
Old Mar 17, 2013 | 09:11 AM
fabmandelux
He's a spammer from Thailand..........
Old Mar 17, 2013 | 03:12 PM
Rushmore X's Avatar
Rushmore X
Spammer, not good. Better run Spybot. thanks
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jul 27, 2012 09:46 PM
frdf250
Jun 7, 2011 04:27 PM
JTSTOY
Oct 18, 2010 02:48 PM
bio-d
May 10, 2007 10:03 AM
Gun-Driver
Apr 27, 2007 10:11 AM
