taillights
Old Feb 3, 2011 | 10:12 PM
shottheif's Avatar
shottheif
taillights
thanks to all that answerd my taillight problem i have one more question about one of the answers if my signal switch was bad why does it still work on the left front are they all on seprate cicurts and brake switch is new it went out few weeks ago any more help thanks again
re;73 f250
Old Feb 3, 2011 | 10:39 PM
HIO Silver's Avatar
HIO Silver
Dang dude... The lack of periods and question marks in your post is a pain in the azz to read. Can ya help us out and parse your sentences? 'Much appreciated.
Old Feb 3, 2011 | 10:43 PM
shottheif's Avatar
shottheif
i most ceartainly will try to rember to have proper english,missed the class in school didnt care for it much.
Old Feb 3, 2011 | 11:02 PM
HIO Silver's Avatar
HIO Silver
'not looking for proper English per se - just some consideration. Thanks!!!!
Old Feb 3, 2011 | 11:04 PM
ArcadeTom's Avatar
ArcadeTom
Originally Posted by shottheif
Thanks to all that answered my taillight problem. I have one more question about one of the answers. If my signal switch was bad, why does it still work on the left front? Are they all on separate circuits? The brake switch is new. It went out few weeks ago. Any more help thanks again.
re;73 f250
Hey, without knowing exactly what answers worked to help you, I can only give you a little help. To my knowledge, yes, they are separate circuits to a point.
The first thing you need to check is your ground connections on each light assembly. Check the connector where it grounds to the body. Make sure it has good and bare metal and a tight connection.
Check the bulb socket for any corrosion or oxidation. If there is any, clean it up.
I have to assume that your brake light switch had to be replaced. If so, and you replaced it, do both brake lights now work? If they do, but your turn signal does not work on the rears, then yes, it will probably be the turn signal switch.
The brake light wiring leaves the brake switch (mounted on the brake pedal) and goes through the turn signal switch assembly. From there they go to the rear tail light assemblies.
This is just a basic description. If you search the forum here, there is probably a wiring diagram that will go into more details, but honestly it does sound like the switch (if all grounds are good).
