scraping sound on hard left turn
Old 06-07-2012, 01:13 PM
v10kenj's Avatar
v10kenj
v10kenj is offline
I'm getting a scraping sound on hard left turns. I've only noticed it on a steep hill where I work going under five mph and making a sharp left turn. I got out today and it doesn't look like the tire is hitting anything. The shield in front of the tire is slightly looser than the right side, but can't see it making the noise unless something is hitting it. I've read some previous posts that indicated traction control possibly coming on. Has anyone experienced similar? I have about 4,000 miles, 20 inch tires, and everything stock.
Thanks
Old 06-07-2012, 02:46 PM
BigDfromTN's Avatar
BigDfromTN
BigDfromTN is offline
Had a similar thing happen when pulling into my drive. Hard left turn etc. Same tires and stock.
I have not investigated as only happened once. Sounded like a tire rubbed to me...
Old 06-07-2012, 04:03 PM
awq134's Avatar
awq134
awq134 is offline
I'm betting it's your traction control applying the brake to that wheel. mine does the same thing when i make a sharp on uneven ground.
Old 06-07-2012, 05:45 PM
v10kenj's Avatar
v10kenj
v10kenj is offline
I was hoping you were right, but just tried it out with traction control off and it's doing the same thing. Talked to the dealer and their saying " if it doesn't do it on flat ground, which it doesn't it's going to be hard to duplicate and diagnose"
Old 06-07-2012, 06:13 PM
awq134's Avatar
awq134
awq134 is offline
about the only other thing i could think of is your CV joint may be binding if it's a 4x4, but i'm guessing it's a 4x2 since you have the 20" wheels
Old 06-07-2012, 09:10 PM
juneau76's Avatar
juneau76
juneau76 is offline
I have a similar issue on mine, turn a sharp corner and hit a bump (small or large). It sounds like the ABS kicking in even if I'm not on the brakes. I'm suspect of the traction control.
Old 06-08-2012, 08:01 AM
v10kenj's Avatar
v10kenj
v10kenj is offline
It is a 4X4. The dealer had swapped the rims out before I bought it with someone who wanted the 18's. If I had know better at the time, I would have insisted that they put a set of 18's back on. That said, I believe that all new lariat, platinum, and king ranch 4X4 trucks come stock with 20in wheels.
Old 06-08-2012, 08:03 AM
BigDfromTN's Avatar
BigDfromTN
My 4x4 has the 20" wheels. Many of them do.
Old 06-08-2012, 10:29 AM
v10kenj's Avatar
v10kenj
v10kenj is offline
I did notice that on top of the ball joint bracket on each side there is a circular piece of steel that sticks out a bit and has a small amount of what looks like black tire marks. The right side looks like its marked a little more. I think this is probably a tire stop, but I don't think it would make the scraping noise I'm hearing.
Old 06-08-2012, 10:33 AM
black_dog's Avatar
black_dog
black_dog is offline
...That said, I believe that all new lariat, platinum, and king ranch 4X4 trucks come stock with 20in wheels.
I have a 2011 Lariat 4x4 that came stock with 18" wheels. Maybe your dealer would trade you if you'd prefer the 18".
Old 06-08-2012, 11:13 AM
v10kenj's Avatar
v10kenj
v10kenj is offline
The owner has two Ford dealerships within about 20 miles. I asked both if they would swap my 20's for 18's and they didn't want to. I had about 2,500 miles at the time and maybe they didn't want to put my 20's back on a new truck.
Old 06-08-2012, 11:42 AM
BigDfromTN's Avatar
BigDfromTN
I have asked dealers about that in the past and they were not willing to due to the wheel size is listed on the window sticker. Some times they trade trucks with other dealers and if they change the wheels... They cant trade it any longer.
Old 06-13-2012, 07:52 PM
nmfiredawg's Avatar
nmfiredawg
nmfiredawg is offline
IS this on the front right? My 2011 F150 does it when turning left on uneven terrain. I thought there was a TSB out on the steering rack for this, since there has been numerous people complaining on it.
Old 06-13-2012, 11:00 PM
SurgIcaltactic's Avatar
SurgIcaltactic
SurgIcaltactic is offline
Lightbulb
Check your shock for scrape marks. When I added the 1 1/2 inch spacer the left shock had scrape marks, seems to be from the coil. Turning right on mine, hit any bump and you hear the noise.
Old 06-17-2012, 05:43 AM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
How long did you depress the TC button? You need to hold it for ~ 6 seconds or so until it starts blinking on the dash. At least thats how mine is, I have the same issue- if I don't disable it sounding like the tire is scraping.
Quick Reply: scraping sound on hard left turn
