Sponsored by: Real Truck
4WD Inop
Old Feb 2, 2011 | 12:45 PM
blacksmokeracing's Avatar
blacksmokeracing
4WD Inop
Having a 4WD problem. 2000 F-250 7.3L. I turn the switch on the dash and nothing, No light no noises or anything. Worked fine on the way to work last night and leaving this morning nothin. Any help would be greatly appreciated.
Thank You
Adam
Old Feb 2, 2011 | 01:09 PM
northwindone's Avatar
northwindone
Have you tried turning your vacuum actuated hubs from "auto" to "manual" yet? It could just be a simple vacuum problem, if that doesn't work then it is probably something more in depth, which I won't be much help with since I don't have ESOF. Someone will be along to help you though if that's the case.
BTW, welcome to FTE! Stick around and you'll be amazed what you learn here.
Old Feb 2, 2011 | 02:35 PM
mixerdrvr's Avatar
mixerdrvr
Thank You
Adam
If you get no light then your motor is not engaging the transfer case. I would first check the fuses and relays. The relays are under the hood. If they are not making good contact or just went out then no 4x4.
AVaang
Sep 25, 2015 07:44 PM
4thesporty
New Member Introductions
May 6, 2015 09:18 AM
Glen66
1947 and Older Ford Trucks
Feb 8, 2015 06:54 PM
Powerstroker32
Nov 17, 2013 10:01 PM
