Engine coolent temp
Old Feb 2, 2011 | 11:21 AM
busdriver47's Avatar
busdriver47
Engine coolent temp
What should the spread be for ECT verse EOT.mine is about 8 to 10 degrees. Thanks
Old Feb 2, 2011 | 11:51 AM
036.0stroke's Avatar
036.0stroke
you should be alright. 15* is the max. above that you have oil cooler issues
Old Feb 2, 2011 | 02:36 PM
Misky6.0's Avatar
Misky6.0
The test is only valid when the engine is fully warmed up @ hi-way
speeds (70 - 75 MPH) flat ground NOT towing.
The ECT should be 190* which indicates the t-stat is working properly.
If the EOT is 205* then you have a 15* delta and the oil cooler
is likely plugged partially. If the ECT never warms up, then the
test is not valid and the t-stat needs to be replaced.
When towing, or going up a mtn the temps will get hotter and
delta get wider that isn't an issue.
Old Feb 2, 2011 | 04:09 PM
69cj's Avatar
69cj
It's also not valid when descending a hill. The ect will cool much quicker than the eot.
Old Feb 2, 2011 | 05:11 PM
ljutic ss's Avatar
ljutic ss
Temperature spread would depend on truck being empty, loaded, speed, and outside temperature. As an example, right now where I live which is a cold climate driving 45-50 mph. level and empty I see a spread of 2 degrees. If I do 70 I will see a 5 deg. spread. In the summer 45-50 mph I will see a 5 deg. difference empty, and at 70 a 8-9 deg. difference.
Old Feb 5, 2011 | 07:12 AM
busdriver47
Mine was warm.was on a 300 mile trip. the oil was about 8 degrees warmer. that was with a scangage thanks for your replys.
