turbo issue
Old Feb 1, 2011 | 09:07 PM
iduger's Avatar
iduger
turbo issue
I have an 05 f250 250k miles on it. this evening noticed i only have about 5psi of boost what the heck. Any suggestions? No check engine light .
Old Feb 2, 2011 | 06:17 AM
Mich6.0's Avatar
Mich6.0
check the rubber hoses( blue) for leaks with soap and water in squirt bottle. might also be a stuck open egr valve,I know my big trucks egr valve stuck full open and it degraded the turbo no boost and lots of black smoke
Old Feb 2, 2011 | 11:18 AM
steelhead2's Avatar
steelhead2
sounds like the turbo might need a good cleaning.
Old Feb 2, 2011 | 11:26 AM
High Binder's Avatar
High Binder
MAP hose clogged or cracked.
Old Feb 2, 2011 | 12:59 PM
iduger's Avatar
iduger
I checked codes today possible icp sensor, code said no turbo boost reading. Does this sound familiar to anybody?
Old Feb 2, 2011 | 01:03 PM
npccpartsman's Avatar
npccpartsman
It would help if you would post the specific code rather than the code description. Sometimes they can mean more than one thing.
Old Feb 2, 2011 | 10:45 PM
iduger's Avatar
iduger
Code is p2262. I was going to install new sensor discovered the map hose popped off intake fitting put it back on noticed hose very stiff will change tomorrow. Truck now has boost, but noticed after its warmed up has a little miss or buck. Could this be the icp sensor going or the vgt valve sticking? Can these sensors be cleaned? Any other help would be great
Old Feb 2, 2011 | 11:58 PM
High Binder
Yep, that's what I figured. Same thing happened to me. I put in a new fitting and new hose. See if the VGT relearn (once you've got it all back together) solves your buck problem before you do anything else.
Old Feb 4, 2011 | 11:47 PM
iduger's Avatar
iduger
Have not had a chance to put new hose yet but first thing in the am. Will disconnecting batteries clear code and check engine light.
Old Feb 5, 2011 | 04:00 AM
npccpartsman
It should.
Old Feb 5, 2011 | 11:07 AM
iduger's Avatar
iduger
Thanks for your help changed hose to map sensor no real change on the buck or miss will clear codes and see if anything comes up again.
