Lucas Oil Stabilizer
Old 02-01-2011, 03:26 PM
lexustbs's Avatar
lexustbs
lexustbs is online now
Anybody use this stuff on their truck? I purchased a bottle of the synthetic stuff, but I was reading on the bottle and it states to only put 1 quart in the power stroke, but for others it says 1 quart to 4 quarts of oil.
http://www.lucasoil.com/products/dis...how&headTitle= - Lucas Synthetic Oil Stabilizer
Read the last line on the description.
Old 02-01-2011, 06:28 PM
rickatic's Avatar
rickatic
rickatic is offline
I have had good results using the manufacturers recommended engine oil for 40 years. If the stuff the aftermarket is peddling is such an improvement over the proper engine oil, why do the manufacturers not recommend using it. JMO
Regards
Old 02-01-2011, 06:31 PM
lexustbs's Avatar
lexustbs
i think you are right. I just did some Googling and it says the Lucas product makes the oil foam, which is really bad for our powerstroke engines. So no on the treatment. I'm going to get the Schaeffer 9000 and run it that way.
Old 02-01-2011, 07:12 PM
F350-6's Avatar
F350-6
F350-6 is offline
Technically speaking, the Lucas causes foaming oil in the Powerstroke engines with a HEUI system, which is why Lucas recommends the diluted ratio.
Skip the oil additive and run a good, properly rated oil and change it on schedule and you'll be fine. Schaeffers has some good oil so no worries there.
DJayAce
Oil & Lubrication
13
05-19-2019 10:56 PM
JoeRod85224
1999 to 2016 Super Duty
02-06-2016 11:54 AM
Lneidlinger
09-29-2015 05:59 PM
DBGrif91
16
10-16-2013 06:01 PM
Nightrain
07-28-2004 04:24 AM
Quick Reply: Lucas Oil Stabilizer
