please help me
Old Feb 1, 2011 | 12:57 PM
cowboyford16's Avatar
cowboyford16
please help me
Hi my name is kody I just signed up. Im doing a diesel conversion into my 90 f-250 with a 6.9 and e40d. I really need to know how wide the adapter ring is between the flexplate and crank. Some specs would be nice or a picture. Thank yu guys. Im 18 and I've put all my money and time into this project I need help badly. Any advice would help I've searched everywhere and can't find one or any specs thank you so much.
Old Feb 1, 2011 | 01:45 PM
swooshcmk's Avatar
swooshcmk
Got a bit more info? What was originally in the truck?
Are you going gasser to diesel? or C6 to E4OD? or a manual to an E4OD? Was the truck originally a gasser with an E4OD? (Gasser E4OD is different bellhousing than a diesel E4OD)????
Old Feb 1, 2011 | 02:51 PM
cowboyford16
My truck was 2wd and a gasser with the e40d the parts truck was 4wd and diesel with the t-19 I used the motor and 4wd out of my parts truck. I just bought a 4wd drive and diesel transmission at the junkjunk yard that came out of a 93. I married the motor and trans yesterday on the ground and I went to slide the convertor forward and it hit the block. I need to know to the thickness of the ring adapter between the flexplate and crank. I can make one at are machince shop if someone could tell me the thickness. Thank you guys
Old Feb 1, 2011 | 03:05 PM
Lazy K's Avatar
Lazy K
Need more info still. What flexplate are you using? When you slide the converter forward why does the flexplate not stop it from hitting the block?
Old Feb 1, 2011 | 03:13 PM
cowboyford16
Bought a 7.3 and its hitting the block cause I need a adapter ring so I can spin the flexplate and tighten the tc nuts
Old Feb 1, 2011 | 06:03 PM
galute's Avatar
galute
Welcome to the forum Kody. I think he's talking about the spacer plate that goes on the end of the crankshaft between the crank and the flywheel. It's about a 1/2 inch or so thick. I've got an old one but it will be a couple days before I can get back to the shop to find it. Maybe someone has one laying around they could measure.
Old Feb 1, 2011 | 06:09 PM
cowboyford16
Galute your right. Thank you very much. I've called everyone in town no one has it. I need my truck so I can go to college in june. It looks so good. I just need that spacer. Like I said before I can make one if I new the exact thickness. Im worried if its to long it will knock my crank out
Old Feb 1, 2011 | 07:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think the crank will make it through just fine.
The transmission, now that would be another story.
Unfortunately I can not help you with the spacer thickness, all out IDI's are manual tranny.
Old Feb 1, 2011 | 07:25 PM
cowboyford16
Thank you dave. I hope someone will know the thickness
Old Feb 1, 2011 | 09:12 PM
galute's Avatar
galute
He needs part number 6376 from the diagram below if anyone has one laying around they could measure for him.
Old Feb 1, 2011 | 09:46 PM
cowboyford16
Yes sir that is that part I need. Thank you so much. Please anyone do you have one laying around and could measure one out for me. This would mean the world to me.
Old Feb 2, 2011 | 11:08 AM
Aune163rd's Avatar
Aune163rd
http://www.dieselbombers.com/wanted-...flexplate.html
If this is what I think you are talking about then I found someplace that sells it.
ereck01
13
Feb 15, 2013 05:16 PM
radical_dreamer
Jul 17, 2008 07:17 PM
GLF-350
Nov 11, 2006 10:40 PM
DPRICE1
Oct 26, 2003 01:39 AM
