PVHLS - Keeps going bad????
Old Feb 1, 2011 | 11:05 AM
DiesalBoyz2000's Avatar
DiesalBoyz2000
Pulse Vacum Hub Lock Solenoid (PVHLS) keeps going bad on my 2000 f250 7.3L. The way I know the PVHLS goes bad is by the heater control defaults to defrost no matter where I have the **** set at. I havent been able to find any air leaks in the hoses. I looked behind the glove capartment and still didn't find any air leaks. My next theory is that the O-rings are leaking in the hubs. My auto hub locks dont work either. I have to get out and lock in the hubs every time. The O-rings that I am thinking are bad are the ones located on the Hub Lock that comes out by sqeezing the retainer ring with a pair of pliars. Any input will be greatly appreciated. Thank You!!!
Old Feb 1, 2011 | 11:17 AM
Ponyboychris's Avatar
Ponyboychris
The hub o-rings that most likely are leaking are the yellow ones on the backside of the wheel hub, not the lockouts. Look at this write-up. Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Feb 1, 2011 | 11:39 AM
Mike F250's Avatar
Mike F250
I have manual (Warn) hubs so I capped the line right by the vac source. You could try this for a bit and just manually lock your hubs?
Old Feb 1, 2011 | 11:52 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have you done this yet? Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Feb 1, 2011 | 12:41 PM
DiesalBoyz2000
Thanks I havent done either one of these maintance's. Ill get right on it. Thank you once again.
Old Feb 1, 2011 | 02:04 PM
clintbonnie's Avatar
clintbonnie
I just replaced my vacuum selonoid ... You can ohm check the 3 lugs on the selonoid.. You should have some resistance between all 3.. If not, replace it..
