Correct tranny fluid ?
Old Jan 31, 2011 | 07:39 PM
DCFord's Avatar
DCFord
Wanted to ask you guys what the CORRECT type of tranny fluid it is that should be used ? I have an '86 Ford F150 XL, with auto tranny (C6 I believe, but not positive). I've been using Dex/Merc and had no issues, but wanted to ask if it should be either the Dex/Merc or Type F?
Old Jan 31, 2011 | 09:28 PM
smashclash's Avatar
smashclash
Nobody is going to (or should) advise you on what type of tranny fluid to use if you don't tell us what type of tranny you have.
Old Jan 31, 2011 | 10:59 PM
DCFord's Avatar
DCFord
Three speed, no OD. But, if that's not enough, then tell me where/how to check/confirm what tranny.
Old Feb 1, 2011 | 02:23 AM
smashclash's Avatar
smashclash
https://www.ford-trucks.com/forums/1...ml#post9904412
Old Feb 1, 2011 | 03:04 AM
TheThickster's Avatar
TheThickster
On my reman. '82 C6 Im running DEX/MERCON and runs great. I went and checked with the ford dealer and they confirmed that MERCON V supersedes the old DEX/MERCON spec. IIRC Type F would be pre-1979, but nowadays pre 1979 transmissions are being rebuilt with clutches made to run DEX/MERC, Ive read on the web that B&M Trick Shift is relabled TYPE F and lots of people use on DEXRON/MERC spec. transmissions. You will be safe using DEX/MERC while its still available or MERCON V if you got the extra cash.
