trans quetion
Old Jan 31, 2011 | 05:28 PM
JoshMcClung's Avatar
JoshMcClung
trans quetion
which transmission came in the 89 f150's with 302? im trying to get a newer one for my 84 while i have the c6 rebuilt.
Old Jan 31, 2011 | 06:46 PM
73FOMO's Avatar
73FOMO
I would guess AOD. If you know the trans is original, check for the transmission code on the label inside the drivers side door.
Old Jan 31, 2011 | 07:28 PM
Jack01's Avatar
Jack01
The AEOD and the AOD first tranny is equiped with electronic OD and the other is AOD mechanical based on shift column linkage Ie there is a tab for OD(drive)
Old Jan 31, 2011 | 08:13 PM
JoshMcClung
thanks for the replies. also on my existing tranny it has 64 stamped on the top of the bell housing and on the bottom by the pan. is that the code? if it is its a different tranny than the vin says
Old Jan 31, 2011 | 09:32 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I have no idea what those numbers stand for, but my Diesel C6 in my motorhome has 1 stamped on it, and I think the C6 in my F150 has 6 stamped on it. Has nothing to do with witch tranny it is that I know.
Only 3 different autos for 1989 half tons.
P R N (D) 2 1 = E4OD
P R N (D) D 1 = AOD
P R N D 2 1 = C6
Old Feb 1, 2011 | 01:26 PM
73FOMO's Avatar
73FOMO
I think those numbers are just casting numbers. Need a picture of the bottom of the transmissions or transmission code to be sure. AODE...wasn't released until after '89...I am still guessing AOD. I had an '88 half ton and it was equipped with AOD.
