FUSE BOX HELP NEEDED
Old Jan 31, 2011 | 04:01 PM
Tennessee Toy's Avatar
Tennessee Toy
Can anyone provide me a diagram for the fuse box on a '61 F100?
Still no brake lights. Do they have a separate fuse? I have blinkers.
have brakes but no brake lights
still trying to resolve.
Its hard to crawl under the dash when your 6'3 and 235.
Old Jan 31, 2011 | 04:22 PM
oldfordcoupe's Avatar
oldfordcoupe
early fords have a s/w out on the master cyl. llok there first
Old Jan 31, 2011 | 06:46 PM
TheThickster's Avatar
TheThickster
so if you apply momentary direct power to the wire that runs to the lights they dont light up?
Old Jan 31, 2011 | 06:58 PM
Tennessee Toy
oldfordcoupe - bought the switch today. in running continuity test to both wires neither one of them lit the light. i figure it must be before the switch.
thickster - explain, sorry for my ignorance
Old Feb 1, 2011 | 12:03 AM
kjvforme's Avatar
kjvforme
Hey Brian, I have a 61 Shop manual, Group 13 Lights, Instruments, and Accessories shows a red wire coming off of the headlamp switch that feeds the stop light switch. It looks like a 15 amp fuse protects the switch. It then comes off of the stop switch back tp the headlamp/fuse switch then to the stop lamps.
Old Feb 1, 2011 | 01:09 AM
TheThickster
Its kew man electrical is a PITA. What I meant was the wire that activates the stop lamps, you know how there is two wires on the pressure switch. If you apply power from a 12v source to the wire that activates the stop lamps will they light up?
Old Feb 1, 2011 | 10:26 AM
Tennessee Toy
brake lights working
it was a bad switch.
brake lights - check = bad switch
engine running great - check = bad fuel pump
emergency brake - check = PB Blaster on frozen up cables
what's next??? time will tell.
i guess things go bad after 50 years - go figure
44,000 original miles, great barn find.
now i will enjoy it some when the weather gets better
you guys are great!
thanks for the help
michaelmrc
Dec 11, 2014 07:36 PM
gizmo6958
Dec 16, 2013 05:57 PM
nexeslee95
Nov 30, 2010 10:20 PM
beachrat
Electrical Systems/Wiring
Apr 30, 2008 07:16 PM
phichee
1983 - 2012 Ranger & B-Series
Jul 1, 2005 05:04 PM
