Engine Size
Old Jan 30, 2011 | 09:37 PM
frdlvr35's Avatar
frdlvr35
Engine Size
I have a dilema that you all can propbably help with. The PO I bought my truck from told me it was a 1978 with a 390 swapped into it. Now when I did some VIN decoding it appears to be the 1979 F150 that originally came with the 400. I am unsure hjow to tell just by looking if I have the 400 or 390 but need to know before I buy parts. Any advice would be appreciated.
Old Jan 30, 2011 | 09:41 PM
tinaheels's Avatar
tinaheels
were is the therostate at? on a 400 its in the block , on 390 its on the intake manifold
Old Jan 31, 2011 | 02:18 AM
Rory428's Avatar
Rory428
A few of easy ways: count the valve cover bolts, 360-390 has 5 per head (3 on top, 2 on bottom), 351M-400 have 8 per head, (4 each, top & bottom).
Or look at the fuel pump, 360-390 has 2 horizontal mounting bolts, bolted to aluminum timing cover, 351M-400 has 2 vertical bolts, directly to block, has flat steel timing cover.
Look at the oil filter, 351M-400 screws directly onto the block, 360-390 has an aluminum oil filter adapter between the block & oil filter.
Look at the distributor, 360-390 goes thru the intake manifold, 351M-400 fits into the block, ahead of the intake manifold.
Check water pump, 360-390 water pump is held on with 4 bolts, 2 per side, and there is a short piece of 5/8" heater hose between the water pump & intake manifold, plus the pump sticks out in front of the aluminum timing cover, on a 351M-400, the water pump is held on with many more bolts, directly to the timing cover.
One of these just has to help you decide what you have.
Old Jan 31, 2011 | 01:30 PM
frdlvr35's Avatar
frdlvr35
It appears that I have the 400. I am seriously wondering about whether there was a rebuild or not. I know she starts right up everytime and runs like a champ. I thank you all for all the tiips. I have been out of the auto game for a few years and this is my first old Ford so still on a learning curve.
kool9
Engine Swaps
Sep 28, 2023 08:13 PM
mustang81
Feb 2, 2013 10:01 PM
mytybug
Mar 4, 2011 10:54 PM
ajoelane
23
Mar 2, 2007 12:05 PM
WillyB
N. California Chapter
Apr 8, 2006 02:42 AM
