4.9 skipping
Old Jan 30, 2011 | 03:47 PM
lillbro11's Avatar
lillbro11
4.9 skipping
I took my 4.9 on a road trip yesterday and got about 20 miles from my house when it started to sputter like it was lacking spark or fuel. I went to an auto parts store and bought a fuel filter, spark plugs, and wires. I unclipped the engine side of the fuel filter and pulled it off and it had quite a bit of fuel pressure built up. I finished then took off and had to stop at the next exit to change the plugs because it hadn't fixed the problem. When I took off again everything seemed perfect and then it started again but only about 1/10 as bad. I'm going to check the dist. cap today. hopefully I find an answer there but if not I'll be needing some advise
The plugs looked as if its lean
Old Jan 30, 2011 | 08:00 PM
88n94's Avatar
88n94
You've got the spark plug wires, replace them the distributor cap and the rotor. Then you'll have an ignition tune up and can go from there if necessary.
