Sponsored by: Real Truck
WHEEL dIFFERENCES
Old Jan 30, 2011 | 02:48 PM
14&Ford's Avatar
14&Ford
WHEEL dIFFERENCES
ok, Im sure its been explained before, but i need to know,specifically, what is the difference between the 99-04 wheels and the 05-11 wheels?
There are some decient buys on ebay of take off wheels in the 18-20" range. what is required to use the newer rims on the 99-04 trucks?
Old Jan 30, 2011 | 03:31 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
back spacing is different due to the new suspension. and of course you cant fit 99-04 wheels on newer trucks because the brakes are bigger. i am sure someone will chime in but i think the lug spacing is different or the lugs are bigger.
Old Jan 30, 2011 | 04:21 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Ok, very detailed question:
Wheel size- 16" will fit pre-05, but not post-05 because of brake caliper changes.
Backspacing- pre-05 was spaced to not contact the leaf springs on 4wd truck, post-05 the coil spring front ends allowed a "tighter fitting" wheel since coils allow the tire to turn further. Later wheels won't work on earlier trucks, early wheels >16" will fit later trucks. 2wd trucks is a realm I don't play in, but I assume since the twin I-Beam is based on a coil sprung beam, later wheels work on earlier 2wd trucks.
Hub bore- many aftermarket wheels are lug centric, while factory rims are hub centric. Not a huge issue usually, but some people complain of vibration and steering problems from lug centric wheels, specifically when either under a diesel engine, or under a heavy bed load. Spacers can be made to use late model aftermarket rims on earlier model trucks, but they can be expensive.
Lug pattern- all SDs with SRW should use the 8 on 170mm pattern. No wheels prior to 99.5 MY trucks will work on a SD. If I recall off the top of my head correctly, pre-99.5 Heavy Duty Powerstrokes used standard lug patterns.
Old Jan 30, 2011 | 05:03 PM
14&Ford's Avatar
14&Ford
I have the 16" chrome clad wheels on my 2004 now. was trying to find an econimical solution to fit some 18" or 20" Rims I thoght this might work.
88dually
Mar 7, 2011 12:11 PM
fastcarz3
Feb 24, 2008 07:16 PM
bkvanbek
Oct 25, 2007 07:25 AM
ghunt
Aug 3, 2006 11:19 AM
