Differential????
Old Jan 30, 2011 | 02:30 PM
Dyllan78's Avatar
Dyllan78
Differential????
I have never change the differential fluid on my 2004 6.0, Should I do this or is it one of those things where if you havnt done it dont touch it.
Old Jan 30, 2011 | 02:43 PM
wulfman's Avatar
wulfman
Dude its so easy go to tech folder there is info there
Old Jan 30, 2011 | 03:32 PM
Dyllan78's Avatar
Dyllan78
The 4x4 disengages but it still makes the noise on the tight turns.
Old Jan 30, 2011 | 03:50 PM
wulfman's Avatar
wulfman
You are in your wrong post, but it sounds like your hubs are still locked. If you were using auto mode they might still be locked. Turn the dial back and forth between free and lock, see if that helps
Old Jan 30, 2011 | 04:39 PM
Dyllan78's Avatar
Dyllan78
That worked thanks a lot. cheers
