fuel injectors
Old Jan 6, 2003 | 09:22 PM
Ford Truck Racer's Avatar
Ford Truck Racer
fuel injectors
Was wondering which is the best injectors and flow rate for stock replacement. Was looking at ford racing 19lb. but was wondering if there where any better ones you guys knew of.
Old Jan 7, 2003 | 12:16 AM
RedLariat's Avatar
RedLariat
fuel injectors
Old Jan 7, 2003 | 12:20 AM
dvldog458's Avatar
dvldog458
fuel injectors
Stick with the Ford motorsort 19 lbs injectors.I run FMS 24 lbs injector and they work great.
Honestly,i haven't heard anyone complain and Ford's injectors.
Old Jan 7, 2003 | 11:01 AM
Lightning2Fast's Avatar
Lightning2Fast
fuel injectors
dont change the flow rate unless you have too. there is really no reason to do so unless your mods are extensive. i know guys making near 400hp on the factory 19s.
Old Jan 7, 2003 | 12:21 PM
keith w's Avatar
keith w
fuel injectors
If you just need some new injectors, KarKraft has new takeouts for $89 for the set.
2001 Bullitt Mustang
1995 Ford F150 302 5 speed
88 LX, down right now
87 LX, down right now
Old Sep 17, 2007 | 10:50 PM
JuniorReb's Avatar
JuniorReb
I am looking for new injectors for my 2004 V10 F250. Anyone recommend any good ones? It has 42,000 Miles on it and I am looking for the ultimate tune up. I want to redo the Spark Plugs, Plugs wires, add a grounding wire kit and a 0 Gauge battery cable. I want the most power out of this that I can get and improve the MPG. Any recommendation s on this, please e-mail me at JuniorReb@aol.com. I check that more frequently.
Old Sep 18, 2007 | 08:20 AM
Conanski's Avatar
Conanski
You can only use an a 19lb injector with a stock computer, so don't even bother looking at anything else. And unless they have 200 thousand miles or more on them you are completely wasting money changing them, these things will last the life of the motor in most cases, with nothing but regular cleaning.
