My Golden Girl
#31
I just need to install new u-joints and press on a new center support bearing for good measure. I'm getting driveshaft vibes and u-joints are sloppy.
#32
One or possibly all three U-Joints (depends on the application), have two different sized cups. Many autoparts stores do not list this joint for 1960's trucks, but they usually have it.
C5TZ4635F .. U-Joint / 2 cups are 1330's, two are 1310's / Spicer part number: 210392-X / This U-joint was used into the 1990's for some applications.
Take the Ford & Spicer part numbers with you when you go to autoparts stores, they can cross them over to the brands they sell.
The only other possible F100 U-joint is common, as it was also used in Passenger Cars. All four cups are the same (1310's).
D9TZ4800A .. Driveshaft Center Support Kit-includes the bearing, shims, brackets and large U shaped rubber support (that by now, is prolly history, as it age cracks and gets oil soaked).
Available from Ford and autoparts stores (I don't have an autoparts store p/n). Fits: 1965/79 F100/250's, some F350's / Misc 1980/91 F100/250's.
#33
Two piece driveshaft: There are three U-Joints, and you may have a problem at autoparts stores finding one of the correct types.
Eric
#34
And...while C5TZ4635F is obsolete, according to the FoMoCo dealer part locator, Sanderson has 14 of them... and 1 D9TZ4800A that is not obsolete.
If you aren't in a hurry for D9TZ4800A, you can buy it cheaper from an FTE Ford dealer parts dept sponsor > >
MSRP: $96.83 // PARTSGUYED.COM price: $69.72 / PartsGuyEd = Horizon Ford in Seattle WA
#35
Sanderson has 1000's of obsolete parts...623-842-8682. I list them so often as a source for parts, I memorized their number.
Longland
10-16-2011 05:33 PM
4dfan
1999 to 2016 Super Duty
10-05-2011 11:14 AM
