cruise control help
Old Jan 29, 2011 | 07:44 PM
Jayme Duty's Avatar
Jayme Duty
cruise control help
My cruise does not work at all. There is no power going to it. with this not working it is confusing the tranny. E40D. when i get up to highway speeds it makes the OD light flash and then the speedo bounces and it shifts extremely hard for 1-2 and 2-3. I have to unhook the batteries and flash the pcm and then it is fine till i have to drive on the highway again. Does anybody have a wiring diagram of the cruise. I have the steering colum apart right now. Also i did some reading on this and found where somebody had a bad tach sensor that was causing similar problems. I have already replaced the vss and thinking that maybe i just got a bad one right out of the box. Where is the tach sensor located.
Old Jan 29, 2011 | 07:51 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Didn't know the E4OD needed a working Cruise to operate correctly?
And heres the tach sensor.
Old Jan 29, 2011 | 07:57 PM
Jayme Duty's Avatar
Jayme Duty
i didn't either but i met a guy that had the same problem, He has the same truck just a 350. we ran the codes on his computer and it brought up the same on he had. Something with the cruise control modular. the problem is the po put in a different steering column because he somehow broke the shifter off. This column is out of a bronco. he never got the cruise hooked up right and i bought it right after he did this so he never really drove it. I didn't think the cruise would give me these problems at time of purchase.
JTHill24
Aerostar
Feb 2, 2017 09:55 AM
Harleyford700
2004 - 2008 F150
Feb 26, 2016 02:28 PM
brobrad
1997 - 2003 F150
Jan 15, 2013 04:10 PM
Ourobos
13
Dec 2, 2012 12:10 PM
paul_pate
16
Apr 11, 2001 03:49 PM
