upper intake gasket
Old Jan 29, 2011 | 04:02 PM
octaneforce's Avatar
octaneforce
upper intake gasket
im going to be replacing my cracked leaky headers soon. i bought a new set of efi manis, got the mr gasket 260, and im planning on buying this gasket for the upper "plenum" (the top half of the intake mani)More Information for STANDARD MOTOR PRODUCTS PG5
does this look correct? it should fit according to rockauto. i just wanted to be sure tho.
is there anything else that i might need? im going to be bringing all the parts to my local exhaust shop.
Old Jan 29, 2011 | 04:27 PM
dustybumpers's Avatar
dustybumpers
yup that's it. you may want to pick up a gasket for the egr too, it has to come off to remove the plenum
Old Jan 30, 2011 | 10:35 AM
octaneforce
good call. i will definitely do that too. thanks
Old Jan 30, 2011 | 10:56 AM
StumpPullerF1's Avatar
StumpPullerF1
Did you get this work done? Just wondering because when i pulled mine off i had a hell of a time. I dont know if someone had done something before but when i tried to reinstall the upper intake manifold i couldnt get the last bolt/stud that goes in from the bottom by the firewall to go in straight or bite. All the other studs went in fine. I couldnt figure it out.
Old Jan 30, 2011 | 11:45 AM
dustybumpers
start them all 1st, then tighten, otherwise the dowel pin kinda warps things. be careful takeing it apart, that same bolt wants to twist off. put a little heat on it, might help to loosen it.
Old Jan 30, 2011 | 03:17 PM
octaneforce
im taking my truck in to have this work done. i dont have the time or patience to mess with it, especially with the cold weather. but theres alot of guys on here who have done it.
