Pull your seat cover back and you will probably see where the wires are burned, then solder them back and you will be good to go! If you don't see any burned wires in the front section ou will have to take the seat out and the wire clips off to remove the seat cover completely.
Thank you, i reviewed all the pages and watched the video. It gives me a good start, but I hope someone comes up with a way to limit the voltage to the seat so it doesn't burn up the wire.
