86 302 doesn't seem right
Old Jan 28, 2011 | 10:02 PM
WGarland's Avatar
WGarland
Hey guys it's been a while since I've been on here. I picked me up an 86 f150 with efi 302 aod. Here is whats happening it will start and idle fine all day long. The issue is driving down the road holding the pedal steady at about 60mph I start losing speed until the transmission senses the rpm and then down shifts to compensate the speed. It can do this all day long and I can actually watch the gas guage moving witin 5 miles. It act like its overloading while driving but its not burning black smoke and I'm not smelling any fuel. I can get 10 mile to a 1/4 tank it sucks. Any ideas or possibilities fro me to look at . Thanks Bill
Old Jan 28, 2011 | 10:39 PM
Franklin2's Avatar
Franklin2
Always check for codes first. Here's a website that shows you how. www.fordfuelinjection.com
Old Feb 7, 2011 | 02:23 PM
dadsgift's Avatar
dadsgift
I had a similar problem and found out a fuel injector was stuck open and dumping fuel into my crankcase. Make sure your oil level isn't going up. My mechanic just tapped on the top of the injectors with a screwdriver handle a few times and it straightened up. Good luck
Old Feb 7, 2011 | 02:29 PM
Uncle Meat's Avatar
Uncle Meat
Always check for codes first. Here's a website that shows you how. Ford Fuel Injection
Absolutely!
I thought I was clever enough to get past this step when I first got my truck.
Save yourself cash, time, and tears and check your codes.
