runs perfectly fine. ill get some pics up in a little while. whats the best place to get motorcraft glow plugs it dosent need them i just figure i might as well do it hoping they arnt autolites
yeah paint and rims will come way later. whats a good place to get some motorcraft glow plugs? i pulled the front 2 and they were autolites but they came out fine didnt look bad at all just hopin the other 6 look and come out as good
Stores in Canada don't have the same names as the States, but when ever I was traveling in the States, I always loved O'Reilley. They seemed to have most of whatever I ever needed on short notice. They should have Motorcraft plugs.
Congrats on the new truck! I knew you could get it for a grand. I have heard O'Reilly's has the Motorcraft plugs. I hope those Autolites don't get stuck on you. I think you got a real good deal with that truck being 4x4 and all. How's the rust?
hardly any rust whats so ever the only rust is surface rust on top of the cab where the paint has peeled away
so everybody the truck was to good to be true. today i went out to start it and it wont fire up. i didnt plug it in last night because its not that cold here. i tried multiple time all day to get it to start but nothing. i plugged it in for about an hour or so thinkin maybe the GP's are bad but still wont fire. it turns over fine and everything i sprayed some startin fluid in just to see if it would work(i know its bad to use but i just had to see and i only used a tiny bit) it fired right up on the fluid then shut off. so im guessing new injectors and injector pump???? but the thing is it ran perfectly fine yesterday started up fine everytime and i drove it about an hour... what do you guys think???
