6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Levels.
Old Jan 27, 2011 | 08:32 PM
ben37505's Avatar
ben37505
Levels.
Question. I live in New Mexico elevation about 7200 feet. What level should my 08 F250 be on in the settings on the cluster? It has 1 thur 10. Or does it even matter?
Old Jan 27, 2011 | 09:51 PM
Larry NCKS's Avatar
Larry NCKS
Welcome, Ben. However, I'm not sure what you're talking about. The only such settings I have would be on my trailer brake controller and those are set according to load. The heavier the load, the higher the number. Maybe someone else here is smarter than I am.
Old Jan 27, 2011 | 10:14 PM
sdetweil's Avatar
sdetweil
I also am not sure what you are talking about..
Sam
Old Jan 28, 2011 | 05:15 AM
senix's Avatar
senix
I think the gain on the TBC is what he is referring too as well. Here is how I set mine for a starting point.
Flat level road that you can get up to at least 25 mph. Then using the TBC only adjust the gain till the trailer will stop both vehicles without a skid but in short order.
Then try both together, adjust as needed.
Old Jan 28, 2011 | 07:30 AM
Tom's Avatar
Tom
Hi Ben, welcome to FTE!
Remember that this number isn't for your gauges, just your brake controller for electric trailer brakes. If you aren't towing a trailer with electric brakes this setting is meaningless.
Electric brakes aren't affected by altitude, the same setting would work at 1,000 or 10,000 feet.
Old Jan 28, 2011 | 02:29 PM
Hunter40's Avatar
Hunter40
Ben-
Are you referring to the compass zone? What part of NM are you in, I'm also from 7200 feet in NM.
Hunter40
briseno
New Member Introductions
Jul 20, 2008 04:47 AM
alamofirefighter
New Mexico Chapter
17
Apr 21, 2008 07:21 PM
WonderDonkey
31
Sep 17, 2007 10:41 PM
kamikazzi
Jun 10, 2007 08:07 AM
geokoppmann
New Mexico Chapter
Apr 2, 2007 10:37 PM
