Recall Help
Old Jan 27, 2011 | 08:15 AM
Tom Hoffman's Avatar
Tom Hoffman
Recall Help
Hey Guys
My truck got recalled for the Body Control Module 10S14.
I called the dealer and they told me it is just a Reflash?
Is this true? I thought the Module was bad and needed replaced, not just a flash.
I asked what a flash would do? He said change peramiters!
I really dont want a flash because i have had no real issues with this truck.
Old Jan 27, 2011 | 08:53 AM
Y2KPSD's Avatar
Y2KPSD
Wrong recall
I think the dealer is mixing this up with the HP/Torque update.
Old Jan 27, 2011 | 09:55 AM
pbruckne's Avatar
pbruckne
It's not a reflash, however, IDS (scan tool) must be used to check the internal BCM board serial number. The lastest software version for IDS must be used 71.01 or higher for the scan tool to be able to check the BCM. IDS will come back with either a "BCM is OK" message or "Replace BCM". Apparently some of the boards were contaminated during production at the supplier.
Hope this helps.
-Paul
Old Jan 27, 2011 | 10:40 PM
rickatic's Avatar
rickatic
Hope this helps.
-Paul
I will say it again...it is great to have you as a resource here...Thanks
