97 Ranger 4L Bouncing Idle
Old Jan 26, 2011 | 02:43 PM
chindi's Avatar
chindi
When my truck comes up to temperature, the idle speed oscillates between 900 and 1300 rpm at about a 10 second rate. There is no CEL on. Listening under the hood and I hear the click of a solenoid activating in step with the idle bounces. There is no whistling or other odd noises coming from under the hood. No trouble starting or dieing otherwise. Any ideas out there?
Old Jan 26, 2011 | 03:09 PM
michigan66's Avatar
michigan66
Try to isolate the solenoid that is clicking. I'd start with the IAC (Idle Air Control). If that is the source of the clicking, try cleaning it with CRC MAF/IAC cleaner. Don't use carburetor cleaner.
Let us know what you find.
Old Jan 27, 2011 | 01:05 AM
Bidwell's Avatar
Bidwell
Compressor cycling? Turn heat/ac to off.
Old Jan 27, 2011 | 01:17 AM
chindi's Avatar
chindi
Thanks for both suggestions.. I'll try then report back.
Old Jan 27, 2011 | 05:13 PM
chindi's Avatar
chindi
Bingo! It is the compressor cycling and it stops when the Climate Control switch is set to OFF. Now what? It's not a normal situation I hope?
cbsbuilder
Feb 11, 2014 12:29 AM
rad1026
Feb 21, 2011 01:21 PM
gb'sfx4
Jul 29, 2010 05:14 PM
Orpackrat
Aerostar
15
Feb 17, 2010 11:21 PM
Turbo_Whistler
Dec 27, 2005 11:18 AM
