Radiator problem
Old Jan 26, 2011 | 06:31 AM
Sheryle's Avatar
Sheryle
Radiator problem
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->I have a coolant leak. I think I found it where the radiator tank and cooling fins connect. My question. Is it repairable or will I have to buy a
radiator ? Thanks for reading and any help.
Old Jan 26, 2011 | 06:59 AM
bismic's Avatar
bismic
From everything I have read, this means a new radiator. Could be wrong, but I don't think so.
Old Jan 26, 2011 | 08:37 AM
lenzhotrod's Avatar
lenzhotrod
Radiator shops can reseal or replace the tank ends. I have had luck with tightening the seal with channel locks myself. Remove radiator pressure first.When I could not seal it I would replace the whole radiator.
Old Jan 26, 2011 | 08:48 AM
teppler's Avatar
teppler
Not recommending this but was surprising, on a past episode of Mythbusters they punctured a radiator and started engine and it had a large leak they added a raw egg in radiator and surprisingly the leak stopped..sorry for the off subject and I'm thinking I would go for the new radiator..
Old Jan 26, 2011 | 08:54 AM
69cj's Avatar
69cj
Radiator vrs. possible new engine? Think I know what I'd do.
Old Jan 26, 2011 | 09:34 AM
bismic's Avatar
bismic
With the plastic end tanks, do they do this as a permanent repair? Do you know if Ford will reseal or replace the end tanks?
As a temporary measure, this certainly would be good to try.
Old Jan 26, 2011 | 01:58 PM
John Irwin's Avatar
John Irwin
A few years back when I was broke(er) I exchanged tanks on 2 rads. I had one from a 460 5 speed that was overheating a little, and I wanted to put it on my truck with a 302 automatic, so I did the swap, and it worked. There was some info in my Haynes manual on how to do it...it involved using a certain size drill bit to limit how much you squeezed the tangs. If I remember correctly, it worked with out leaking.
So maybe you could try to fix it, if you screw up, it doesn't matter, you have to buy a new rad anyways if it doesn't work.
They used to have a big flat o-ring sealing them together, and you might be able to squeeze it tighter.
Old Jan 26, 2011 | 05:33 PM
69cj's Avatar
69cj
No offense but your not talking about a small block 302 here. Your talking about a $14,000 motor. Radiators are not cheap but " Do you feel lucky today"
Old Jan 26, 2011 | 06:12 PM
cheezit's Avatar
cheezit
we send them out for repair as needed. ford will only sale a new one.
gangstakr
Mar 12, 2015 04:00 AM
natira121
Jul 31, 2014 04:52 PM
bbogus
May 18, 2012 12:51 PM
rob188
Escape & Escape Hybrid
Jul 29, 2010 10:37 PM
grico777
22
Jun 22, 2010 06:31 PM
