Code Scanner
Old Mar 9, 2003 | 09:06 AM
magic-dot's Avatar
magic-dot
Code Scanner
I've got a 96 f150.. I want to read the codes but $200 is a little out of my league right now for a scanner.. I don't suppose there's any way to read these codes w/ a multimeter or anything other then this scanner is there? Does anyone have one of these scanners used that they are interested in selling? Know where to find one used for cheap?
Old Mar 9, 2003 | 09:57 AM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
Code Scanner
where do you live
Old Mar 9, 2003 | 09:58 AM
magic-dot's Avatar
magic-dot
Code Scanner
Originally posted by Diesel_Dummy _
where do you live
Pennsylvania/Delaware line..... ???
Old Mar 9, 2003 | 10:11 AM
94van's Avatar
94van
Code Scanner
eBay?
Old Mar 9, 2003 | 10:25 AM
mantta's Avatar
mantta
Code Scanner
I bought a code scanner from ebay for around $20.00.
Old Mar 9, 2003 | 11:26 AM
geevoor's Avatar
geevoor
Code Scanner
AutoZone does this for free. Just stop buy the store near u and ask.
Old Mar 9, 2003 | 01:04 PM
steve83's Avatar
steve83
Code Scanner
Many parts stores pull OBD-II codes free now, so don't go to the zone unless you ABSOLUTELY have to.
Old Mar 9, 2003 | 01:21 PM
Leo_T's Avatar
Leo_T
Code Scanner
Hello,
I have the newer technology in my '96 van.
I just posted this question myself. Hopefully someone has some good news about the newer scan tools. I've seen some of them in action, and it's amazing the data they can retrieve. I guess the cheaper scanners can retrieve a code number, but the more expensve ones can give real time activity and record abnormal behavior. They can be hooked up and left there while the car is driven, and can pick up intermitant problems.
If you have a laptop with windows 95 or 98, they sell an interface for around 70 bucks, that will turn your computer into a sophisticated scan tool. You can also hook it to a desk top with windows, but you need a long cable to hook up, an the car can't be taken for a ride.
batauto.com has reviews on these scanners. I would like to hear from someone with real world experience with them.
Thanks
Old Mar 16, 2003 | 10:43 AM
magic-dot's Avatar
magic-dot
Code Scanner
But, from what I've read, these scanners only pull codes if the check engine light is on.. ..I don't have that yet, but there's got to be someone going on.. I used to jump on the gas and spin wheels, but now i'm lucky to beat a gremlin off the line. I've replaced the plugs and wires, fuel filter (which both helped a little) and now I'm thinking I need to test the fuel pressure.. do these scanners that can read while driving tell you all the pressures and mixes that are going on?
Old Mar 16, 2003 | 11:13 AM
steve83's Avatar
steve83
Code Scanner
Not all codes turn on the MIL, so stop by a parts store and have them checked. I don't think you'll see any actual numbers since the computer doesn't use numbers that would make any sense to you. There might be some expen$ive software packages that turn the readings into useable numbers (like flow rate of the injectors, estimated hp, etc.), but they wouldn't be much use to the typical shadetree/weekend mechanic.
