Factory amp bypass
Old Jul 6, 2011 | 09:55 AM
Ford Strokin' 96's Avatar
Ford Strokin' 96
Shoot a pic of it Superduty4x4. And is this on the 97??
Old Jul 6, 2011 | 09:59 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by Ford Strokin' 96
superduty4x4- Did Talyn's post solve it for you?
No...
I realize I can just buy a new adapter harness and get the job done, I've just never seen anything like what is in my truck currently. I'll go take a pic...
Old Jul 6, 2011 | 10:16 AM
superduty4x4
Shot of all the wiring between the head unit and the factory wiring:
Shot of the harness going from the head unit to the white connector:
Close-up of the OEM stereo wiring plugs on the truck:
Old Jul 6, 2011 | 10:46 AM
Ford Strokin' 96
Yup. Definitely looks modified. I would certainly just pull that off and buy the Wal-Mart harness and plug her right in. It'll come with what I think is 4 plugs. Obviously you will only need the two that are required for your year model. The power harness and the speaker wire harness (shown in your photos coming out of dash) Wire that new aftermarket harness into the Kenwood head unit and plug her up. Don't forget the blue remote wire to turn your factory amp on.
Old Jul 6, 2011 | 10:59 AM
plgebbia's Avatar
plgebbia
Hey Chase, maybe your truck had the Ford CD player from the factory, didn't it have a different plug-in on it?
Old Jul 6, 2011 | 12:11 PM
superduty4x4
Yes, the trucks with the factory CD player had the factory amp. My 97 did have a factory installed CD player.
Old Jul 6, 2011 | 12:27 PM
plgebbia's Avatar
plgebbia
That is why the wiring is different then, I guess.
Old Jul 6, 2011 | 12:36 PM
Talyn's Avatar
Talyn
Well, again, you are wrong. The harness is most definitely different. I'll go take a pic if I have to. If you used the "standard" harness and your truck does in fact have the factory amp, you bypassed it.
Edit- look at the photo, the one on the left and the one on the right are matches to the connectors in my truck
Thank you king ******* know it all.
I got the same setup as you.
And no I didn't bypass it.
I have that connector as well.
Old Jul 6, 2011 | 12:39 PM
Talyn's Avatar
Talyn
oh and.
Oh so sorry i forgot about the other connector.
It was only 2 years ago I put my radio in.
I forgot.
Old Jul 6, 2011 | 12:41 PM
superduty4x4
Maybe, just maybe, before you go flapping your gums, you should make sure you know WTF you are talking about Slick *****.
Old Jul 6, 2011 | 12:45 PM
plgebbia's Avatar
plgebbia
You guys can't get along, can you?
Old Jul 6, 2011 | 12:48 PM
Ford Strokin' 96
Yes. This is the Premium Sound System wiring. Two harnesses from the dash. The wider flat harness plug is the power harness and the smaller more square harness is the speaker harness. The power harness comes out of the factory amp and the speaker harness goes into the amp on the other side and powers the speakers. If you purchase the Ford harness from Wal-Mart for this particular year model, both plugs are on it to plug your head unit in. And again, if you hook up the blue remote wire from the Wal-Mart harness to the blue remote wire on the head unit, everything works properly. Just do away with the harness between your head unit and the two harnesses coming from the dash and add the new (Wal-Mart) harness. That's all. If you DON'T have a blue remote wire on your head unit, let me know. Make sure to check the wiring chart for your head unit. It is a possibility the remote wire might not be blue. But it should.
Old Jul 6, 2011 | 01:15 PM
  #28
Ford Strokin' 96
You can still use this harness. Just cut the plug off to wire into Kenwood Head Unit. If the Kenwood has a plug coming from the wiring on the Head Unit, cut that sucker off too. You'll just have to know your color schemes. If they aren't labeled on the harness that is in between the truck and the head unit now, I recommend getting the new one. They are on there for ya. Then you just have to know the Kenwood Head Unit wire colors. I guess I'm understanding you correctly. You want to yank that head unit in the picture and put a newer one in this truck?
Old Jul 6, 2011 | 01:35 PM
  #29
Ford Strokin' 96
Guess everyone went to Wal-Mart! Haha!
Old Jul 6, 2011 | 01:36 PM
  #30
superduty4x4
OK, I feel like a complete dummy... I'll have to look at my other harness when I get home, but the one currently wired to my Kenwood head unit has 2 different plugs on each harness. I'm betting I can switch which one I was using for the speakers to match the factory wiring in my 97. This is what I get for trying to put the CD player in after a long day in the heat and being frustrated...
I'll look at it again when I get home and post up tomorrow if it works.
