'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
FAQ - Factory tachometer installation
Old Apr 11, 2010 | 11:57 PM
  #76
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Thought that was the whole point of ACC, Nothing but Accessories... I guess gauges are accessories!
Gee I wonder if the ignition is on as well ...
-Enjoy
fh : )_~
Old Apr 12, 2010 | 12:33 PM
  #77
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Fordzilla80
That and the fact that the green printed circuit is non-tach while the red printed circuits are tach circuits.
Actually all 1980 cluster printed circuts are green. Non-Tach, tach and gauges, and idiot lights. I have a green 1980 tach printed circut that needs to be fixed.
All 1981-1986 cluster printed circuts are red. But have seen some of them faded to clear or a ruddy brown color.
Old Apr 12, 2010 | 01:20 PM
  #78
81-F-150-Explorer
Originally Posted by Rogue_Wulff
Wow, it's as simple as swapping 17 & 18? That's too easy........
Also, it follows what fordzilla has said about only having the (r?) turn indicator and brake warning indicator switch places. Would 17 and 18 be those 2 curcuits, by any chance?
Originally Posted by ri_truck_guy
No....left directional and seat belt warning light.
Hmmm, my seat belt warning light will have a heck of a time trying to work without a bulb.....
That's odd, as I'd figured it was those other 2.....
That is because there are four circuts changed between the 1980 and the 1981-1986 clusters.
Two circuts are changed within the main wiring harness at the cluster connector, and two circuts are changed in the cluster printed circut itself. That equals four.
Since swapping the 1981/1986 cluster is only changing two of the circuts in your 1980, you have to change two of the circuts in the main wiring at the connector of the 1980 to compensate. Either change the two circuts to mimic the 1980 light bar pattern, or change the two circuts to mimic the 1981-1986 light bar pattern. And that depends on if you want to use a 1981-1986 instrument cluster bezel or keep your 1980 one, I suppose.
That's how the four lights, (right and left turn indicators and the seatbelt and brake warning lights) are swapped around between the 1980 and 1981/1986. Two circuts are changed in the cluster printed circut, and two are changed in the wiring at the cluster connector itself.
Hope this makes sense.
Old Apr 12, 2010 | 02:00 PM
  #79
Rogue_Wulff's Avatar
Rogue_Wulff
I still haven't tried doing this yet, but I will likely use the entire 1985 cluster. Not only does it have the tach, but also has a trip odo as well.
I hate the high beam indicator in the 80. It's so bright it will blind ya. The newer clusters had most of the high beam indicator blacked out, and just a small blue icon, where the 80 is a blue lens with black icon.
The 85 cluster is in the bronco I am going to be getting the 4wd system from and swapping under my truck. Probably do it all at the same time.
Old Apr 12, 2010 | 02:38 PM
  #80
TheKirbyMan's Avatar
TheKirbyMan
Like others have said, it should just be a drop-in deal. Save yourself the frustration and time and test your circuit film prior to installing the gauges, though. I didn't, and this is going on the fourth time I'll be pulling the gauges back out. lol.
I didn't know that about the different indicator. Huh.
Old Apr 12, 2010 | 07:32 PM
  #81
81-F-150-Explorer
Yes, 1980 and 1981 Instrument cluster bezels have different indicator covers.
The 1980 is the most different, with it's lights being reversed ordered.
1. Blank | 2. FASTEN BELT | 3. <---- | 4. HI BEAM | 5. -----> | 6. BRAKE | 7. 4x4
1981-1986 are the same order as follows.
1. Blank or EMISSION | 2. <------ | 3. FASTEN BELT | 4. HIGH BEAM | 5. BRAKE | 6. -----> | 7. 4x4
The 1980 and 1981 share lenses though. The high beam is a large solid blue light with the word high beam in black letters. The turn indicator arrows are the full length of the space.
1982-1986 the High Beam letters themselves are the only thing lit. and the turn arrows are very short by comparison.
I'll try and post some pictures when it gets dark.
Old Apr 12, 2010 | 07:40 PM
  #82
Fordzilla80's Avatar
Fordzilla80
81-Explorer,I got a strange one for ya..here's my old bezel(1980)
If anybody is wondering,the two indicators on the outside both say 4x4,even though my truck is 4x2.And as far as I know,there's only supposed to be one 4x4 indicator light.
Old Apr 12, 2010 | 07:43 PM
  #83
Fordzilla80
LOL,I was referring to the two pictures I posted on page 2.The picture of the green circuit is a non-tach,and the the two red circuits were tach circuits.That was the other difference between the two.
Old Apr 12, 2010 | 08:50 PM
  #84
Rogue_Wulff
Now tha you mention it, I believe mine has an orange on each end as well. Never looked closely enough to see if both say 4x4 though. Mine is also a 2wd, for now. I might have to do a little modding, and have dual 4x4 lights, just cause I can........
Old Apr 12, 2010 | 09:01 PM
  #85
Fordzilla80
Make sure you grab the 4x4 light harness.Can't have the light without it.lol.I'm not sure if our trucks are prewired for it or not though,as i've never really checked.Might do that tomorrow.
Old Apr 12, 2010 | 09:09 PM
  #86
Rogue_Wulff
LOL, I used to have plenty of the pre-wired 194 bulb sockets, so I can make my own dual 4x4 light wiring, if need be.
Old Apr 12, 2010 | 09:22 PM
  #87
Fordzilla80
lol.When I got the new interior for my truck,the donor truck just so happened to be a 4x4,so I grabbed the light harness,and then I decided to just take the entire interior wiring harness from the truck.So,now I have endless replacement wires for my truck,including the ones for the 4x4 indicator light,so if these trucks aren't prewired,I can take care of it the factory way.
Old Apr 12, 2010 | 09:39 PM
  #88
Rogue_Wulff
Yeah, the cluster is coming from the 4wd donor, so it should have the factory harness. I'm taking the tilt column out of an F100, so as to prevent turn signal switch issues. My switch is broke, so the tilt column is not only an upgrade, but a repair at the same time.
Old Apr 12, 2010 | 10:14 PM
  #89
81-F-150-Explorer
LOL, that is strange, as it's only got one. Probably another weird 1980 only quirk.
My 1981 is blank on the first one.
Old Apr 13, 2010 | 12:58 PM
  #90
TheKirbyMan
Got an update and a question.
The update is that I've been running the tach on a 4 amp fuse (not 4.5 as I first thought), and I've had no issues with blown fuses or strange electrical behavior. Everything seems to be good.
The question: My factory tach reads about 150rpm lower than my Sunpro tach. Is there a way to correct this, assuming it's in the factory tach, or is it a small enough difference that it's not worth messing with?
