swapping gears
I've got an F150, 4.6, auto with the 3.08 rear end (believe that's right)and 255 tires. I've got a great opportunity to get a 20ft, 3500 # travel trailer. I know the truck will pull it down here in the flatlands, but I really want to take it up into the Rockies this summer. I don't drive like a mad man, and doing 40 or 45mph up a mountain would be fine with me.
will a gear change benefit the truck and be worth the cost?
any other ideas?
thanks again.
If you go to a junk yard, you might be able to find a decent axle from a 4x4 with a 3.55LS or even a 3.73 for a couple hundred bucks. 4 ubolts, and reconect some brake lines and your in buisness.
Make sure you look at 8.8 axles if you go this route. The 9.75 axle requires a different driveshaft.
