EGR Problem
Old Jan 24, 2011 | 06:20 PM
jv2290's Avatar
jv2290
EGR Problem
I have a 1992 F250 with a 5.0 E4OD and I have a problem with the EGR system. When I'm driving along at a lower RPM with a steady throttle, the engine will have a "wavey" RPM / Vacuum supply. I have a vacuum gauge and it'll bounce around a lot when it does this but the tach doesn't really move. So I made a block plate for the EGR and it stopped doing it. It hass still all hooked up but nothing flowed through. I might just leave it blocked but if it's a simple fix I'll just repair it. What causes this? I've never had a code. It's been like this for a very long time. Vacuum hose are brand new too! is it the vacuum regulator or EVP? I'll leave it blocked if it's too much. This truck is trouble haha! Thanks in advance!
Old Jan 25, 2011 | 10:53 AM
jv2290's Avatar
jv2290
ANd I have another question too. Is The EGR vacuum regulator/solenoid cleanable? I thought I heard about a way to clean them?
Old Jan 25, 2011 | 11:33 AM
rla2005's Avatar
rla2005
Yes, the EVR can be cleaned. I have personally never performed this task but it can be done.
Old Jan 25, 2011 | 11:41 AM
subford's Avatar
subford
No you can clean them but if the filter goes bad from age you need to replace the solenoid.
