Painting a bumper
Old Jan 24, 2011 | 11:47 AM
thebig350's Avatar
thebig350
Painting a bumper
Well, I got sick of looking at my 2 tone bumper (chrome and rust), so I decided to tackle it last weekend. I know it's not a big time mod that really needs a write up, but it may help some who don't know if they want to take the plunge or not.
The before:
Removed bumper (4 bolts) and removed moulding (plastic pinch clips on the back side), washed it down front and back. Using a 60 grit sanding pad with my angle grinder I sanded the entire bumper to remove the rust and any flaking or loose bits of chrome. I'll point out that a 60 grit on an 11k rpm grinder will eat metal away pretty quick, so don't sit on a spot too long or you'll make divets. It is imperative you do the full exterior bumper surface to make certain no chrome chips flake off later. Pay particular attention to the edges of the flaked or peeled chrome so that you don't have lines. After the 60 grit, I changed to a 120 grit and went over the surface again to feather it and give it a consistent looking surface. I then primered and wet sanded twice at about 30 minutes apart using a self etching primer that was wet sandable. I let it cure overnight and started again in the morning after 14 hours of curing time. I used rustoleum high performance enamel in a semi gloss, and gave it 3 coats with wet sanding in between the coats spaced at 1 hour. Let that cure overnight as well (I let mine go 24 hours before handling it). Reattached the moulding and the bumper in the morning, the surface is silky smooth, and the truck is starting to look like the pimp-mobile that it is.
Afters:
Total cost: 20 bucks in paint, 10 bucks in sanding pads, 15 bucks in Shiner Boch.
Thanks for reading, lemme know if you have any q's.
Old Jan 24, 2011 | 11:53 AM
riverrat41's Avatar
riverrat41
I think it looks really good.That really bring out the grill you just fabbed and painted.
Old Jan 24, 2011 | 03:12 PM
427 fordman's Avatar
427 fordman
I think it looks good too. For a few bucks it sure looks a lot better than rust and chrome!
npd23
18
Mar 24, 2021 08:18 PM
xjcamaro89
2004 - 2008 F150
Jul 23, 2013 08:53 PM
BadDogKuzz
46
Oct 18, 2012 09:01 PM
TexasEx
1966 - 1977 Early Broncos
26
Nov 23, 2010 04:53 PM
grandmas77f150
Apr 6, 2010 09:57 AM
