need more power rr rr rr
Old Jan 24, 2011 | 07:24 AM
mammothstroke's Avatar
mammothstroke
i have a 92 7.3 .thanking of a banks turbo kit latter but for now would like to turn up the fuel.How do you go about doing this.my books dont tell anything in great detail.I 'm looking for some ford shop manuals.But for know i will ask the expert's.
Old Jan 24, 2011 | 07:26 AM
snaponprofile's Avatar
snaponprofile
Do you have a pyro??
Old Jan 24, 2011 | 08:13 AM
Aune163rd's Avatar
Aune163rd
You need to put a pyro kit in and then guess and check with the pyro what your EGT's are. Do not let them get above 1000F at the manifold as the heat will damage the pistons.
Old Jan 24, 2011 | 11:33 AM
BlueOvalBud's Avatar
BlueOvalBud
Turning up the fuel on a N/A engine without a better exhaust setup for better flow is like playing with fire.
Install a pyrometer gauge, then start opening up the exhaust, then start experimenting with how much fuel you can supply.
Here, this is a pyro kit...and the one I think I'm going to install on my truck someday.
Auto Meter 2654 - Auto Meter Z-Series Analog Gauges - Overview - SummitRacing.com
For the sending unit/probe, you'll want to pull your exhaust manifold off the engine. Drill it out and tap for threads. Point that sucker right into the rear-most cylinder if you can. The closer you can get to the pistons, the more accurate your reading will be. 1200 degrees is the max you want to run before the pistons begin to melt.
The stock Y-pipe in the exhaust is beyond horrible.
6.9L And 7.3L Naturally Aspirated Diesel Y-Pipe Exhaust Modification .: Articles
Open up the exhaust as large as possible...you want that heat GONE with an N/A motor.
Then, open up the intake. These IDI's LOVE air, and LOTS of it.
https://www.ford-trucks.com/forums/1...od-v2-1-a.html
Open up the grille so you can get more cold air directed into your intake.
The colder you can get your intake air, the lower your EGT's will be...and the more fuel you can supply the engine.
For more power on an N/A engine...more air, more fuel, WAY Faster and more exhaust flow out.
Old Jan 24, 2011 | 01:20 PM
snaponprofile
You don't have to take the manifold off. You can drill and tap it with the manifold right there on the engine. Taking it off would make it easier but its unnecessary.
Old Jan 24, 2011 | 01:51 PM
Aune163rd's Avatar
Aune163rd
My Y-pipe doesnt do what his does in the article. THey are 2.25" pipe off the manifold, but they both come together right at the pipe to the muffler, when i upgraded my exhaust to 3" i cut into where the two pipes came together and the hole i cut was about 2.5 inches long and 2 wide. I put my new exhaust pipe onto it and welded it together and it took about an hour to get done. The muffler was not a straight through but it was high flow. When i fired it up and started driving around, i noticed that the power increased when i started out in second. It increase a Little in Third and almost nothing in fourth. I did notice that it breaths a little easier now that i did that. I just need to figure out how to let her breath more.
Old Jan 24, 2011 | 02:13 PM
gumper 123's Avatar
gumper 123
TURNING UP FUEL CHECK THIS OUT
How to turn up fuel on 6.9/7.3 IDI - TheDieselGarage.com
Old Jan 24, 2011 | 02:20 PM
gumper 123's Avatar
gumper 123
TURN UP FUEL
you will find it easy to do but i highly recomend pyro could be expensive if not carful.
Old Jan 24, 2011 | 06:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
when looking for more power,always start with a fresh tuned up engine:
How to tune up the IDI diesel every 100k for peak performance and economy.
after that,start with more air in,and more air out.
after that,a pyro and fuel.
johnkn
2009 - 2014 F150
Apr 29, 2013 05:26 PM
A/Ox4
59
Dec 22, 2011 08:01 AM
throwdown
Mar 23, 2009 03:26 PM
92 f150300six
Jan 15, 2004 11:12 PM
