add a leaf drive shaft angle?
Old Jan 23, 2011 | 08:52 PM
79350Ranger4x4's Avatar
79350Ranger4x4
hi , i have a 79 350 4x4 . bought it with a 4" superlift... new springs in the front . blocks in the back.... the front end sits an 1" or so higher than the rear . what is the best way to level it out.... will i be messing my driveshaft angle up by insatalling an add a leaf? if so how do i correct it? thanks for any info.....
Old Jan 23, 2011 | 11:07 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Should be ok with a JCW $80 add-a lift, if it does give you a bad d/s pinion angle put a shim kit on the front end.
Cheap and easy, and post some pics, we all love pics.
