79 400 backfiring? HELP
Old Jan 27, 2011 | 03:43 PM
78 PEB's Avatar
78 PEB
Sounds like you are starting to get it nailed down.........The low compression on one cylinder would point to a burnt, stuck or improperly seating valve. Have you run a wet compression test yet? That would help narrow it down further.
Old Jan 30, 2011 | 11:39 AM
alex severson's Avatar
alex severson
I dont know if this will help but when was the last time you changed you fuel filter, my truck was doing the same thing till I changed the fuel filter and put some seafoam stuff in in the fuel filter ran then let it sit over night.I started it the next morning, backfired 1 or 2 times then ran great ever sense.
Old Jan 31, 2011 | 10:39 AM
1979super4x4's Avatar
1979super4x4
just a suggestion but if you r runnin a holley carb have you tried changin out the power valve i no i went through a few of them before i got p off and riped the peace of s@#* off and slaped an edelbrock on
Old Jan 31, 2011 | 12:09 PM
Roller150's Avatar
Roller150
Like Alex said make sure your fuel filter is cleaned too. I changed everything out and it cleared up the backfire issue. Now I just need to rebuild the carb so it runs even better. Holly 4180 4br.
Old Feb 1, 2011 | 11:40 AM
radar457's Avatar
radar457
you might check your vacum advance. I had a similar problem and was at wits end as to why it backfired and lacked power. Found that the vac advance had gone **** up and turned into a vac leak.. replaced it and problem solved..
Old Feb 1, 2011 | 12:42 PM
Roller150's Avatar
Roller150
RADAR457, You really have that many dents?! If so how long did it take you to collect all of them? Where did you get most of them?
Old Feb 3, 2011 | 01:10 PM
Goker73's Avatar
Goker73
well the vacuum advance was bad I changer it but still have the problem. The way I see it I will have a new truck soon.
Raymond Birkle
Jan 15, 2017 11:35 AM
Cam_
Mar 3, 2016 07:30 PM
manlikesford
Feb 2, 2013 10:06 PM
OrangeBeast78
Jul 11, 2011 03:20 PM
78bigunns
13
Feb 26, 2011 08:27 PM
