is there a way to wire a stock 351 disty without using the module i had a different disty before i got this one and there was no module. i have a red wire and a white wire coming out of the fire wall with no plug. when i hook up the whit wire do i go right to the silinoid or do i have to splice that wire to anything? and the red one is power?
White is start/retard and red is hot in both crank and run for a DSII system.
If you have orange, purple, black coming from the distributor it's a DSII dizzy and not the TFI one.
