Truck hell please help!
Old Jan 23, 2011 | 12:54 AM
Adamjmerideth's Avatar
Adamjmerideth
So I was driving my truck 2 days ago and all of the sudden I lost engine power. So as of now it will idle a little rough like its missing and will rev in neutral but when you go to drive the truck barely had enough power to go 5mph.
So here it'd whats been done, new cap rotor plugs(copper) wires icm. Ignition timing has been checked 10 times i have 41psi at the fuel rail noid light says all injectors are firing and if I put a 9v battery on each fuel injector I can hear it open and watch the pressure drop i have put a spark tester on each cylender and it is more that hot enough also one bt one and
Old Jan 23, 2011 | 01:04 AM
Adamjmerideth
Watched each plug spark next to the noid light and looked good all the compression is@ 120-130 i have also inspected the entire wire harness and pulled the right valve cover only to find it clean well oiled and functioning..
Wtf!! Oh and if I spray starter fluid in the tb idle is better and the power is back....
89 f250 with a 351 efi (no maf) motor has 10k on a rebuild by previous owner if any one can help it would be awesome!
Old Jan 23, 2011 | 01:07 AM
Adamjmerideth
Other than the o2 sensor and the icm what controls the air/fuel and or fuel timing?
Old Jan 23, 2011 | 04:27 AM
CALIFORD's Avatar
CALIFORD
Sounds like a distributor issue...Are you reading fuel pressure under load or static
Old Jan 23, 2011 | 06:37 AM
fdude64's Avatar
fdude64
sounds like a fuel filter to me. even tho there is good pressure at idle there may not be enough delivery to run it under load
Old Jan 23, 2011 | 08:55 AM
Adamjmerideth
Sorry I also replaced the filter and pressure was tested In park all thoughout the rpms and then in drive with foot on the brake and gas
Old Jan 23, 2011 | 09:05 AM
TUFFY's Avatar
TUFFY
Any codes? Could be a clogged converter. This may sound funny but my 90 was doing this turned out to be the tps.
Old Jan 23, 2011 | 10:02 AM
aguitarestv's Avatar
aguitarestv
check all vacuum lines to, my truck was running similar when the egr had no vacuum to it.
Old Jan 23, 2011 | 11:55 AM
CALIFORD's Avatar
CALIFORD
Should check fuel pressure under a load, static pressure may read 41 (without vac) at idle...but a load changes pump demands as the injector pulse (BTW) is the filter installed correctly...just saying
Old Jan 23, 2011 | 05:20 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
check the tps as well, Just had mine go bad and caused me all kinds of problems including running at times like you described.
Old Jan 23, 2011 | 06:32 PM
garywh's Avatar
garywh
sounds like tps is cracked,,replace it,,make difference
Old Jan 23, 2011 | 08:09 PM
tayberry73's Avatar
tayberry73
same problem with my 91, atempted to fix by checking or replacing all of the above, try unbolting your cat at the flange and see how it will run, fixed my problems, installed a new cat and it runs like a champ now, hope it helps
Old Jan 23, 2011 | 08:54 PM
Hotshot869's Avatar
Hotshot869
Yeah like stated before, mine did the same thing!! pissed me off for about a week, then i took a gamble bought a new TPS and it has performed excellent ever since...could be your TPS..
