Offroad & 4x4
4x4 wont always disengage
Old Mar 8, 2003 | 08:33 PM
Border3899's Avatar
Border3899
Hey all, we got about 6 inches of snow last night so of course i needed to use my four wheel drive, well it engages just fine but it will not always disengage. To get it to disengage i have to continue to take in out of 4 and put it back in, take it out, put it back in....you get the picture. Any idea's? It does have manual hubs if that helps.
Truck is a 91 F150.
Old Mar 9, 2003 | 05:50 AM
Pdlandshark's Avatar
Pdlandshark
Of course make sure you unlock the hubs and then back up in reverse for about 10 ft, I have been told this helps disengage the 4x4. Landshark
Old Mar 9, 2003 | 03:26 PM
Stokes's Avatar
Stokes
do you really have to back up with manual hubs??? i thought that was only for the auto hubs due to it being the same action as hand turning the *** backwards by hand.
Old Mar 9, 2003 | 11:13 PM
steve83's Avatar
steve83
You have to back up slightly with manuals just to make sure there's no driveline bind keeping the springs from pushing the locks out. A foot should be plenty with manuals, but Ford always recommends 10' just to make it easy to remember. It's possible for them to unlock the moment you turn the dials, but it doesn't hurt to roll back slightly.
Old Mar 9, 2003 | 11:35 PM
Pdlandshark
He beat me to it. But he's right on the money.
Old Mar 10, 2003 | 09:04 AM
Border3899's Avatar
Border3899
Normally i wouldnt have a problem unlocking the hubs and backing up, but right now i have to keep them physically locked in because there's enough snow on the ground where i may need to have the four wheel available right away. Backing up isnt a problem, but even with the hubs locked in if i back up it still doesnt disengage all the time. Thanks guys!
Old Mar 10, 2003 | 09:47 AM
mrshorty's Avatar
mrshorty
So it's not disengaging at the transfer case, right? Do you have electric shift or manual shift?
Old Mar 10, 2003 | 11:57 AM
Border3899's Avatar
Border3899
It is a manual shift. When i lock in the hubs and engage 4X4 everything is fine, then when i go to disengage it will not always disengage until i keep manually shifting it in and out of 4.
Old Mar 10, 2003 | 12:54 PM
mrshorty's Avatar
mrshorty
Don't know about the specifics on the F150, but on my BII, I've heard talk of having problems with bushings on the shift linkage getting worn. I also have a cam plate that provides the "stops" for the shift lever, and it can be adjusted to make sure the "stops" are in the right place.
Old Mar 11, 2003 | 05:15 PM
Border3899's Avatar
Border3899
Any one know if this is the same for the F150?
Old Mar 12, 2003 | 09:51 PM
steve83's Avatar
steve83
You'll have to crawl under and see. The shifter may have plastic or steel bushings where the links are connected, and they may be worn, but I've never seen one that bad. If you have to pull or push your shifter sideways to go thru the t-case ranges, you DO have the indexing plate, but since there are 2 BIG bolts holding it on the trans extension, I doubt it could get out of alignment.
Old Mar 13, 2003 | 10:06 AM
Border3899's Avatar
Border3899
I dont think i have the indexing plate because i do not have to pull the shifter sideways. I'll crawl under there tonight to double check though.
