engine returns to idle slowly?
1st let me say thanks for the help with my choke problem. The choke works fine now. The problem now is that the motor is slow to return to idle after acceleration. I thought the throttle might be sticking, but I went out and revved the motor up by hand with the throttle linkage, and it snapped back quickly. I even closed it by hand just to make sure it was closing complety, and it did. After the thottle is closed, it takes the engine about 4 or 5 seconds to return to normal idle. what would cause this? this is an 86 351w HO 4 barrel motor in my 1978 f100. thanks once again, Ben
2 questions...
Is the secondary throttle plate staying closed (and adjusted properly)?
Is there a dashpot on the throttle that is doing this? Some calibrations use this feature to keep the exhaust from popping (sounds like a backfire) when the throttle is closed.
Kyre Searcher
215
11-07-2014 08:22 AM
Rusty_S
12-12-2012 02:24 PM
yellow78ford
03-23-2007 12:29 AM
cjben
04-06-2003 01:10 AM
