Offroad & 4x4
clunking still
Old Mar 8, 2003 | 06:56 PM
trucker41's Avatar
trucker41
clunking still
Bought a 83 F350 manule lock out hubs awhile after I bought the truck I put it in 4 wheel drive and it made a clunking noise said no big deal front hubs are shot before long wheel drive quit working. Put in new hubs four wheel works again but I still have a clunking noise coming from the front end. but only when in four wheel drive. Did notice when I put new hubs on the shaft moved up and down a little don't know if this is the problem or not . Any help would be greatly apreciated. Let me say it is not a clunk clunk clunk but a clunk go alittle ways clunk go alittle ways clunk etc.
Old Mar 8, 2003 | 08:31 PM
RCrawler's Avatar
RCrawler
clunking still
Check the front axle u joints.
Jason
Old Mar 9, 2003 | 03:28 PM
Stokes's Avatar
Stokes
clunking still
i second u-joints
Old Mar 9, 2003 | 03:39 PM
xanthias's Avatar
xanthias
clunking still
Disconnect the front axle and give her a try then--no clunk = you have isolated the problem.
Old Mar 9, 2003 | 06:43 PM
FordPerf300's Avatar
FordPerf300
clunking still
I also say it's a U-joint.
That wobble in the shaft can lead to excessive wear on the hubs and burn them out quick. Pull off the spindle and replace the bearing, they are only $10 per side.
Old Feb 21, 2006 | 02:30 PM
taker73044's Avatar
taker73044
Im having the same problem
im haveing the same problem as described as above but along with the clunk drive clunk drive every time it clumks the front end jumps like i hit something when im in 4 wheel any ideas
Old Feb 21, 2006 | 02:56 PM
StillaKilla187's Avatar
StillaKilla187
My friend blew up his front locker, and it clunks every few feet, also the front wheels will not engage.
Old Feb 22, 2006 | 04:11 PM
bremen242's Avatar
bremen242
I bet one of both of the spindle bearings are hosed, probably ujoints too.
Old Feb 23, 2006 | 05:33 PM
knapikmichael's Avatar
knapikmichael
i just changed my 250 2 manuals u have 2 use a ring snap clip and repace u joints have fun
Old Feb 27, 2006 | 12:39 PM
cardchvy's Avatar
cardchvy
hi my name is dan and i was wondering if a bad lock out hub would make my 1992 ford f150 clunk and jump out of four wheel drive can somebody please help me because i just bought the truck and want to figure it out
Old Feb 27, 2006 | 01:04 PM
chrono4's Avatar
chrono4
well dan, it helps if you start a new thread, but hell anyway if its jumping out of 4wd at the t case it prolly needs rebuilt
Old Feb 27, 2006 | 01:26 PM
cardchvy's Avatar
cardchvy
no because the tcase was just rebuilt a year ago so i think it is the manual hubs on the front of it
Old Feb 27, 2006 | 09:18 PM
chrono4's Avatar
chrono4
well, i dont see how the hubs could do it, but hey watever.
