Universal Joint question
Old Jan 22, 2011 | 09:45 AM
fernesto's Avatar
fernesto
Exclamation Universal Joint question
Hi,
I just bought a 1995 Ford F250 4x4 off a guy. It has 96,000 miles on. The guy at some point took to to the shop about a noise when he had the 4WD on. The mechanic said it was the Universal Joints and they needed replaced. I have never changed U joints on a 4WD vehicle. How would I go about changeing them on this truck, and is there anything else I should change while im changing them??
Thanks
Old Jan 22, 2011 | 10:00 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...-u-joints.html Here is a link to a good writeup on doing them. You don`t have to go as far as the ball joints but if they show any signs of wear might be a good idea to do them as well when you are that far in.
Old Jan 22, 2011 | 11:37 AM
drjoe171's Avatar
drjoe171
not sure if this applies but it would be safe to mark
their orientation to the shafts and to each other.
Somehow I got a driveshaft out of 'alignment' with the
u joint yokes and had to start over with no reference points.
It was hideously out of balance.
Old Jan 22, 2011 | 05:30 PM
fernesto's Avatar
fernesto
Thanks. The link helped me out a lot.
