u joints
Dont weld it though.
One time a needed like a hairs width to get it to go in all the way so i took my grinder and took a little bit off of the snap rings. But i would recommend NOT doing that since it is stupid and dangerous. The only reason i did it to mine is because i am very rarely over 5 miles from my house so it would not have been to big of a deal if something would have happened.(Live in a kind of small town). 7,000 miles ago and it still there, but still i dont recommend it.
If you do ever have to weld a cap to secure it you are better setting a washer on to the cap and tack welding the washer to the yoke.
I've also broken a needle or 2 doing that and jam a needle piece in the end cap so it will Never go in all the way.
I just love my shot filled deadblow hammer but it sounds like you need an extra paper thickness and maybe one more sharp ka Rack with a scary hammer.
I'll bet you've notices that the keeper snaprings may be punched, meaning one side is flat and the other is sorta curved from being stamped out of a sheet.
If that's the sort of thing you're looking at, you've gotta be close.
What's a needle diameter btw? are you THAT far out?
I've chipped needles and had tiny pieces lodge in there too.
or even dead particles from the old one.
I also remember having to get a tiny dremel wheel and clean out the snap ring grooves.
I just hope you're not using a snowbank for a workbench from the looks of the weather channel this morning.
Good luck.
Makes me want to go check and grease mine.
