12V Keyed Accessory Wire?
Old Jan 21, 2011 | 08:37 AM
EpicCowlick's Avatar
EpicCowlick
Does anyone know of a good wire to tap into that will provide a "power-up" signal for the on-board air compressor? This needs to be just a signal wire, not the running load wire for the compressor.
Here's the wires available in the drivers foot well. Any of these?
Old Jan 21, 2011 | 09:26 AM
EpicCowlick
Never mind. I found one in the fuse box that I will use. Thanks anyway.
Old Jan 21, 2011 | 09:44 AM
HADaChevy's Avatar
HADaChevy
How bout for a plow signal switch? Will any of those wires pictured work? It needs the same 12v keyed, I have it to an upfitter switch which works fine for now, but soon I'm sure I'll find a better use for that switch...
Old May 1, 2015 | 12:07 PM
93-331-29PSI's Avatar
93-331-29PSI
I'm installing a dash cam and it needs both battery and keyed ignition connections. Curious as to where you made your connections in the fusebox. It's pouring rain today or I'd go at it with an amp meter or test light. If I can get an idea I'll at least have a game plan for when the rain stops. Thanks
Old May 1, 2015 | 01:48 PM
darren32's Avatar
darren32
Yellow - orange would have been the one in that bundle.
Not hot while cranking tho which is kinda annoying.
Old May 1, 2015 | 01:52 PM
darren32's Avatar
darren32
DOH another EPIC thread bump
Fuse 52 is keyed ignition source but not sure about on a 2015. Supplies power to the PCM tho so if you blow it your not going anywhere......
Skm0807
Electrical Systems/Wiring
Apr 22, 2017 08:13 PM
JefflovesF250s
Dec 13, 2016 08:16 PM
kegger66
Jul 13, 2016 08:39 AM
xkpsanit
Nov 28, 2015 10:57 AM
