6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Regen
Old Jan 20, 2011 | 07:20 PM
jam105's Avatar
jam105
Regen
I have a job 3 - 2008 KR F-350
I drive about 15 miles to work one way.
The problem is that most times when the truck goes into regen my trip is not enough to complete. Now that Ford removed the display that indicated regen until it was completed I find myself missing the regen.
Is there a way that i can manually put the truck into regen when I know I'm going to be on the road enough to complete the cycle.
Truck does not have a tuner and is all stock.
She has 31K on the clock.
Old Jan 20, 2011 | 08:05 PM
StanleyZ's Avatar
StanleyZ
Some of the experts may know something else but I don't think you can. It would make sense that the computer would tell you when it needs cleaning and let you pick the time within some time frame. But it doesn't and how you drive the truck is, as best as I can learn the absolute worst thing for the emissions systems. Hope you're keeping a close watch on your oil level and the fuel dilution. There is a ton of information on the forum on the subject.
Old Jan 20, 2011 | 08:11 PM
senix's Avatar
senix
there is a device out there that can be purchased to do a manual regen. www.partsguyed.com knows about it.
He is out right now due to an illness. If I can find it I will post it for you.
Old Jan 20, 2011 | 08:17 PM
senix's Avatar
senix
Here is the link for the DPF regeneration tool:
https://www.ford-trucks.com/forums/9...ml#post8975126
Old Jan 20, 2011 | 08:18 PM
jam105's Avatar
jam105
Thanks that would be great
Old Jan 20, 2011 | 08:21 PM
jam105's Avatar
jam105
Yep understood.
When I first picked up the TK it was a 55 mile trip but we moved and it is much closer...Been thinking about picking a 3rd vehicle but even with the price of fuel it would never pay for it's-self.
Old Jan 21, 2011 | 07:24 PM
galaxie641's Avatar
galaxie641
If you want to trigger it as soon as possible I have noticed a few things that help.
First I have noticed an obvious change in the exhaust smell when it is getting close to
a regen. Using that and knowing how any miles it regens around, when I pull on to a
65mph road I floor it up t 65mph and set the cruise, this has set the regen almost
immediately a few times now. I also have a 15 mile drive and the dang thing kept
waiting until mile 5 or 10 before it would start then I'd have to go the long way or do
some other extra driving to try and do a full regen, I also slow to 55mph some times to
try and get it to finish. I also need closer to 20 miles to regen most times which doesn't
help.
This is all done with the engine at least warmed to above the low mark on the temp gauge. I wouldn't be flooring a cold engine nor do I think it would regen that quick.
Old Jan 21, 2011 | 08:17 PM
StanleyZ's Avatar
StanleyZ
Originally Posted by jam105
Yep understood.
I only use mine for RV trips. My daily is a 92 Acura I bought in 92 and have 220K or so miles on it. It's still fun to drive and the depreciation curve is pretty flat now. I guess I was wrong about the forced regen. first time I've heard of that gizmo. I'm not sure I would give 500 bucks though. I'm more inclined to go the other way and spend the money to get rid of the DPF. I'm hoping the repubs will just close the EPA to cut spending then we can get rid of all of them.
city_dweller
Jan 10, 2016 05:16 PM
Mtncrash1
6.7L Power Stroke Diesel
Oct 28, 2015 08:40 PM
Dascro58
Jul 1, 2015 08:31 AM
jdcass
Sep 12, 2012 07:28 PM
rednek01
Feb 4, 2009 04:03 PM
