6.0 no start
Old Jan 20, 2011 | 04:44 PM
ezzyke's Avatar
ezzyke
6.0 no start
Ok just bought an 07 250 with the 6.0 last week. ran fine got up this morning and now it won't start. It is out of warranty and is setting pending faults for all 8 injectors. for ckt to low. Any ideas?
Old Jan 20, 2011 | 05:18 PM
Surge08's Avatar
Surge08
I would say HPOP
Old Jan 20, 2011 | 06:44 PM
bayou barataria's Avatar
bayou barataria
Yep, sounds like hpop seal or pump. Time to take it to the dealer.
Old Jan 20, 2011 | 09:33 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jan 20, 2011 | 11:03 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Do you know anyone with a Snap on or Auto Enginuity scanner? Might just be an IPR.
Old Jan 20, 2011 | 11:29 PM
m-chan68's Avatar
m-chan68
Awwww c'mon guys. I'm very disappointed in everybody that replied. The OP clearly states he has hard fault codes for all eight injector circuit low codes. We ALL should know by now what that means, RIGHT?
And to ezzyke, you may want to check your warranty in-service date, because if it is later than late-January or early-February you may still have warranty coverage unless you are over 100,000 miles. But in answer to your question, your FICM is burned out and needs replacement with 100% certainty.
Old Jan 21, 2011 | 02:31 AM
carltonwebb's Avatar
carltonwebb
Where in GA r u? I am outside Athens
Old Jan 21, 2011 | 09:28 AM
raiderarc's Avatar
raiderarc
hey chan i had same codes low circuit voltage all injectors replace ficm still no start replaced harness still no start but have no codes now truck sat with batterys off for 2 mths is there any programming involved for ficm or some kind of pcm lock like some cars when they sit have to reboot pcm
Old Jan 21, 2011 | 11:53 AM
m-chan68's Avatar
m-chan68
If you purchased the FICM from the dealer, it will need to be programmed with IDS to work.
Old Jan 21, 2011 | 04:20 PM
bayou barataria
Do the women who work with you know about this web site and what is in your sig?
Old Jan 22, 2011 | 12:16 PM
raptor131's Avatar
raptor131
yeah, that's classic LMFAO!
Old Jan 29, 2011 | 08:52 AM
ezzyke's Avatar
ezzyke
FICM was only sending 20 volts. Pulled it shipped it overnight to a guy in MN for 225 dollars plus shipping had it back in two days. runs like a champ.
Old Jan 29, 2011 | 08:56 AM
ezzyke's Avatar
ezzyke
Thanks for the help by the way guys and to carltonwebb I am from Lincoln county but live in Augusta now.
