I have a 2005 E-450 ambulance that has no backup alarm or lights. I know the box is OK because I can power that circuit manually and it works. The box is not recieving the signal from the truck. Does anyone know which pin on the trans connector is the reverse signal? I figure it is the range switch/sensor in the trans, but I want to know what i am doing instead of educated guessing. Thanks
