Thanks, guys
Anyway...rarely do I see a place that has been so helpful to me. My '02 F250 is my first diesel vehicle and I'm having good time learning how to work on this thing thanks to the info found here on the forum.
This past weekend I pulled the turbo and turbo pedestal, did the EBPV delete, installed new O-rings, installed a HPx, removed the insulation/foil from the hot IC pipe, did the CCV mod, and rebuilt the fuel bowl...and every bit of info needed was on this site.
I also ordered a 650 dash from RifRaff so that will go in when it gets here. 2 gauges, 3 switches (momentary for train horn, on/off for Air and 110V), and a DP tuner mount. Boost and EGT gauges are on the way (AutoMeter Z-series) so they will go in the 650 dash initially. I'll sort out final placement when I decide which other gauges/gauge mounts I want to get.
Anyway, you guys have corrupted me.
Thanks.My truck, for anyone interested.
https://www.ford-trucks.com/forums/9...o-install.html
Awesome post on your truck. I enjoyed the explanations and pictures of everything. The CD cover was awesome.
The knowledge on this site is aamazing and the people that are here and willing to share it are the best of the best.
