1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Rear Axle Seal Replacement - Is it a DIY Job?
Old 09-24-2013, 12:06 PM
swoosh's Avatar
swoosh
swoosh is offline
Do have a fuel pressure gauge? External that you can hook up at the fuel rail? Also did you get the brake issue worked out?
Old 05-16-2016, 06:59 PM
raenglehart's Avatar
raenglehart
raenglehart is offline
Old thread I know, but I was doing this for the first time last weekend. When I pulled the hub, the slinger fell off and I had no idea of it's orientation during new seal install. Also the old seal half of it stayed on the spindle. So, after getting that off and putting the new seal on, I realized I really had no idea as to how to orientate the oil slinger. None of these threads seem to mention it during install, but I was on my cell and away from a computer, so put it on as I thought it should go. Lucky me, I was WRONG!! Tore that seal to hell. Now that I'm on a computer and better searching forums, I found this from Diesel Dave that does show orientation of the Slinger during install. Please pay attention to this very important step and you won't be like me and having to do a seal job twice. But on the bright side, like someone else here mentioned, I can now do a hub seal in 30 minutes or less.
Note here: F-250/350/Super Duty Axle removal & Here F-250/350/Super Duty Rear Hub Seal Job
Old 05-29-2016, 06:15 PM
2005powerstroke4WD's Avatar
2005powerstroke4WD
2005powerstroke4WD is offline
How important is the Oil slinger thingy? I just had to replace a bearing(outter) and mine doesn't have the oil slinger thingy. I replace the seal after checking the inner bearing. The Pass side of my truck did not have the Oil slinger between the bearing and seal. So is it really require? Where would I get one if it is? TIA,
Edit,
I have a F350 Dually, just noticed the thread is for the F250, but not sure if they are the same. I am hoping I won't have to worry about it.
Old 10-01-2016, 04:16 PM
Royson12's Avatar
Royson12
Royson12 is offline
I would like to know the importance of that slinger also. I am doing my rear seals right now, and one of my slingers is broke?
Old 10-01-2016, 10:07 PM
Zmann's Avatar
Zmann
Zmann is offline
no idea
but i have a feeling something wasn't getting the proper amount of lube and created some warranty issues
Old 10-04-2016, 02:12 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
A slinger is a oil control part. it slings the oil in a favorable designed direction. i.g. away from the seal. It should be replaced.
Old 10-04-2016, 03:45 PM
Zmann's Avatar
Zmann
Zmann is offline
the name " oil slinger" gives away the function so no question what it does
but many years had the same setup with no slinger and I don't hear of oil starvation issues
the slinger was solely responsible for my bearings being wiped out
it was hard to reinstall that 5$ part in my case since it wiped out 100's of dollars worth of parts
Old 10-05-2016, 12:44 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
I have this job in to do list. Anyone happen to recall how much time the job took?
I get the extra fun of doing the parking brake backing plates too.
Thanks for the good links.
Sean <BR>
6.0L Tech Folder
Old 10-05-2016, 02:33 AM
Royson12's Avatar
Royson12
Royson12 is offline
in doin the backing plates on the yeller sub. ill give yiu a rundown, once im done.
Old 10-05-2016, 10:22 PM
Zmann's Avatar
Zmann
Zmann is offline
if you have the special socket in hand you can do a side in just over an hour not rushing
but add the backing plates and i assume their rusted so that can add unknown time
Old 10-06-2016, 12:32 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Not a lot left after the rust had it's way. And yes I do have that
socket and the step plate if I have to use a puller to get the hub off.
Sean <BR>
6.0L Tech Folder
Old 10-06-2016, 02:58 PM
Royson12's Avatar
Royson12
Royson12 is offline
like this? lol
  #28
Old 10-06-2016, 05:53 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Originally Posted by Royson12
like this? lol
Close but not quite so bad. Are both sides the same on your?
Mine dropped the passenger side shoes and they started to
rub on the drum so they got removed as a quick fix.
Sean <BR>
6.0L Tech Folder
Anthony Polsinelli
05-06-2018 05:00 PM
yzf450motoxrider
07-05-2017 02:55 PM
Amish65F100
05-08-2017 12:08 PM
WolfCreek540
04-10-2017 12:56 AM
1966f250
10-11-2016 02:33 PM
Quick Reply: F250 Rear Axle Seal Replacement - Is it a DIY Job?
