Cold Weather Window Fogging
Old Jan 18, 2011 | 12:45 PM
FBNengr's Avatar
FBNengr
Question Cold Weather Window Fogging
Hi All,
New to the forum here, although I have been lurking for a few months. Lot's of good info. not to mention great pictures!!!
Have a question - on my '73 dentside (my very first Ford truck, brought it home labor day weekend 2010!), I am getting a little bit of window fogging in cold weather. Not bad, but just enough to be annoying.
Back in the good 'ol days (mid/late 70's, early 80's) I experienced a few heater core leaks in various vehicles, which would fog everything over very thoroughly. Of course, the problem was obvious, you could see (and smell) the antifreeze spittin' out on the floorboard when the heater core decided to blow a leak.
Currently in my truck, I can neither see nor smell any antifreeze leaking from the heater core. But could possibly a very minute amount be seeping from it and causing my mild fogging problems? Or is there some other affliction these Fords have, that I am not aware of? Any thoughts or ideas??? (By the way, heat only, no air conditioning).
Thanks in advance for your replies!
Paul
Old Jan 18, 2011 | 01:32 PM
Justin's Green Truck's Avatar
Is the condensation on the inside, or on the outside of the windows?
Old Jan 18, 2011 | 02:02 PM
FBNengr's Avatar
FBNengr
Would be on the inside only. Cracking the driver's window slightly to allow some fresh air doesn't really seem to help, either.
I have put a little electric space heater in the cab, and allowed it to run for an hour or two in order to "pre-heat" the cab interior before driving. Seems to help, but there still can be a slight amount of fogging, depending on how cold it is.
Old Jan 18, 2011 | 02:25 PM
Could the carpet or seat have gotten wet from rain water? That might be something to look around for.
Also, does turning on the heater/defroster make it worse?
To answer your question, yes the heater core could be leaking just a little and staying in the heater box. What little was coming out of the box might be getting soaked up by the carpet to where you wouldnt notice it. Usually though, like you say, youd smell it. But not always. I would feel of the carpet (if it has carpet) and of the seats. If they're wet, look at all the body seals to see if water could be getting in any where.
So, you havnt noticed the coolant level in the radiator dropping any?
Old Jan 18, 2011 | 02:54 PM
FBNengr's Avatar
FBNengr
Interior dry as a bone. No carpeting, just rubber mat. Fogging occurs with either heat or defrost, really no difference. The more I think about it, the more I'm starting to think that maybe there could be a tiny little leak in the core. Not big enough to drip coolant, nor enough to really smell it. But just barely enough weepage or dampness somewhere in there to foul the air as it flows through the core.
Thanks Justin, unless somebody else offers any different ideas, I may just assume that I need to scrutinize the heater core next time I get a chance.
Paul.
Old Jan 18, 2011 | 06:42 PM
F-250 restorer's Avatar
F-250 restorer
If you do a search for 'heater upgrades', there is quite a bit of info about how to replace/seal up the vents to make the heater work great.
